Results 1 to 4 of 4
Thread: H100 question
    Apr 2012
    H100 question
    These just arrived http://www.newegg.ca/Product/Product...82E16835706018
    When i get home im going to install on my h100. Question is do you think my temps will drop a little more with 2 x 190cfm fans going thew the rad ?
    Intel Core i7-3930K @ 4.4 1.285 v ( idle 35 load 62' )
    ASUS Rampage IV Extreme
    16g (4 x SAMSUNG 4GB 1600) @ 2138 10-10-10-28 1t 1.5v
    ASUS GTX 670 DirectCU II
    HD1: 2 x SanDisk Extreme 120GB SSD Raid 0 - Os/games
    HD2: 2 x Western Digital Caviar Black 640GB - storage
    XFX 1250W PRO Black Edition PSU
    Coolermaster Haf X EATX Tower Case
    Coolmaster H100
    Feb 2008
    sunderland
    Quote Originally Posted by m00se View Post
    if you getting 62c on you core with it under load there is nothing to worry about some oc'ers is running these cpu's at 80c
    and to be honest using really high rpm fans just make more noise
    get 2x fans with high static pressure instead they will do a better job
    something like the corsair sp120mm performance fans scythe gentle typhoon 1850 rpm fans
    see below
    corsair fans : http://www.overclockers.co.uk/showpr...=2331&subcat=4
    scythe fans : http://www.overclockers.co.uk/showpr...=2331&subcat=4
    best one to go for are the noctua fans but are expensive
    Xtreme Guru
    Mar 2004
    steelcity.pa.usa
    I run my H100 and H80 with Corsair SP120 Performance fans. Cougar Vortex CF-V12HPB are also excellent replacements.
    STARSCREAM
    3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
    Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
    WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
    Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
    ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
    MEGATRON
    3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
    SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
    WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
    Corsair AX650 | Corsair H80i
    Jun 2008
    Bonnie Scotland
    Running my I7-E 3960X @ 4600MHz with Corsair H100 with the Corsair SP120 fans for less noise, what a difference in less volume but practically no difference in temps I can see.
