Review Quote:
I found some interesting features on this case, which some may like or not. I liked the screwless removal of the side panels by these plastic slide releases. I also liked the vent in the right side panel right behind where the CPU is normally located. This will vent some of the heat produced by the CPU. Also on the right side panel up front and next to your hard drives is a spot for a 80mm fan. In the front panel you have the option to mount a 120mm fan at the bottom. On the right side panel there is a spot for a 80mm fan that would blow air across the video card. And bringing up the rear there are two spots for 80mm fans. So let's recap the fan situation. Four 80mm's and one 120mm capability. Plenty of cooling options.
Read it here.
Please feel free to add comments below about this review.
