Does anyone know if the current EK FC-Links for the dual/triple serial/parallel bridges will work with the EK 600 series blocks?
Ω Raven Build Blog
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
" Inter Arma Enim Silent Leges" - In times of war, the law falls silent.
They do. I'm using the Triple Parallel Bridge with 3 GTX680s.
Hardware: CaseLabs T10 | REIV | 3930k @ 4.8 | 16GB Mushkin 1600mhz 8-8-8-24 | 3x GTX680+ 4GB Tri-SLI | 2x 240GB Cherryville raid0 | 2x 3TB Barracuda | CEntrance DACmini CX | HiFiMan HE-500 | 30" Ultrasharp U3011
Watercooling: EK-Supreme HF | 3x EK-FC680 GTX | EK-FB Kit RE4 | MCP35X2 | 2x Alphacool UT60 | XSPC RS360 | EK-Multioption RES X2 250 Advanced
Thanks Jay.
Ω Raven Build Blog
Check product description page:
http://www.ekwaterblocks.com/shop/ek-fc680-gtx.html
Up to four EK-FC680 GTX series water block can be interconnected with EK-FC Bridge & Link system. The correct connection link for this water block is EK-FC Link GeForce.
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
tiborrr: what's a reason for making them separate for amd/nvidia blocks? Isn't it simpler to stick to one inlet spacement for all the blocks, thus only one range of FC bridges?
Ω Raven Build Blog
