Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Thread: GTX 670 OC - Result-Thread --- Post your MAX results here
    May 2009
    IND
    Cool GTX 670 OC - Result-Thread --- Post your MAX results here
    I'm in............
    give me u'r best score
    May 2005
    Montana, USA
    The GPU-Z screen doesnt really mean much on its own.. you need to list what clock your card boosts to under load. The boost listed under GPU-Z is only a guarentee, all cards usually are running higher.
    i7-2600K @ 4806Mhz 102.3x47 1.368v LinX stable
    MSI P67 GD-80
    16Gb Corsair 8-8-8-24 1T 818.2Mhz
    MSI GTX560Ti 1005/2250 1.062v
    Crucial m4 256Gb SSD
    Corsair TX850 | 64bit WIN7 Pro
    Custom watercooling
    47" 1080p LCD | Onkyo 876/ Polk 5.1 surround
    May 2009
    IND
    Quote Originally Posted by LexDiamonds View Post
    as i remember +160 core clock
    GTX 670 SLI OC
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    Fun start in this thread
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Xtreme Mentor
    Feb 2008
    Heres my settings, and I managed to loop 3x heaven runs twice and it was completely stable with <70 degree temps to prevent throttling:
    I only got an average GPU unfortunately, only 1250 Mhz which the majority of GK104s are capable of, but my ram was stable in heaven up to 7350 MHz, but artifacting in 3D mark 11 until I turned it down to 7200 Mhz (still really good).
    3Dmark11 - 10124 overall score, 10029 graphics score
    Vantage - P42441 with GPU Physx, P37202 with CPU Physx, 36204 Graphics score
    Max settings heaven 3.0 @ 1080p, 1267 points
    The KFA2 was only £35 more than a reference card, worth it for the cooler alone if you plan to keep it on air, but the Gigabyte and Asus cards have better coolers and lower temps due to having direct contact heatpipes.
    _______________________
    I decided to make a couple of videos of the installed cards this time:
    And screenshots:
    The blue PCB is a letdown, but both of the only avaiable full length PCB and custom cooled versions on launch in the UK had blue PCBs unfortunately (Gigabyte and KFA2), and the Asus non top with reference clocks was £11 more on pre order, so I went with this KFA2. It also came with a free GPU keyring as a promotional offer
    Mar 2004
    Just started overclocking my eVGA GTX 670 last night. Only the GPU so far, memory still stock, was stable in Heaven benchmark with 140+ offset. This was good for a max of 1279MHz on the boost clock in Heaven. Load temps during benchmark stabilized at 74C at these settings, and did throttle back 10-23MHz once over 70C. This eVGA card is the reference cooler, and standard non-SC version.
    i7-2600K|Thermalright True Spirit 140
    Asus P8Z68-V Pro/GEN3
    8GB Corsair Vengeance 1600 MHz
    eVGA GTX 670
    Corsair Force GT 120GB boot drive
    Corsair HX750
    Corsair 650D chassis
    Win 7 x64
    Jan 2008
    Scotland/Poland
    Mine is quite good GPU TBH.
    KFA2 EC OC.
    Here is heaven 3.0 maxed:
    Boost 1328 MHz
    And here 3DMark 11:
    Boost 1349 MHz
    GA Z87 X OC // 4670K // 2x4 GB Samsung Green // Intel 520 180 GB SSD // Noctua NH-U14S // Seasonic X660W // Phantom 630 // win7 64
    Mar 2004
    Pushed mine further last night. Got it up to +135MHz on the GPU and +400MHz on the memory (1258MHz GPU boost, 3400MHz Memory). Scored this in maxed Heaven:
    eVGA GTX 670
    Corsair HX750
    Win 7 x64
    May 2009
    France
    Quote Originally Posted by Blackwhite View Post
    KFA2 EC OC.
    Boost 1328 MHz
    And here 3DMark 11:
    Boost 1349 MHz
    nice card
    I7 2600k @4.5ghz, Maximus IV Extreme, 4gb Gskills Ripjaws X pc 17000, Velociraptor 300go, Asus 660 GTX , HAF 932, Coolermaster M1000, Watercooling
    3930k, Asus R4E, Gskills Ripjaws X , SSD Samsung 840 pro, SLI 780TI Inno3d Ichill, Corsair 900D, Lepa G1600W, Watercooling
    Asus R3E Black Edition (RIP)
    Jan 2008
    Scotland/Poland
    Thanks mate,
    Any way - It was as I swapped for Asus DCU II, clocking worse (1304MHz), but much quieter, and cooler too.
    c[_]
    Nov 2002
    Alberta, Canada
    Put my DCU2's in.. bumped to max power level in MSI afterburner and havent touched boost yet. Card 1 does 1254, card 2 does 1293. Card 1 runs a bit warmer than card 2.
    All along the watchtower the watchmen watch the eternal return.
    Xtreme Guru
    Jul 2004
    I got the evga FTW edition. Its should be here in the next hour or so from UPS. I'll uninstall the 6950 drivers and get the new drivers going and post some results.
    EDIT..
    I got the card. I'm finally on it. anyone have some pointers as far clocks go just to start out? I'm using the evga precX tool. what exactly is boost and how do I control it? I got an error right after heaven finished 26 and no score.
    this is all new to me. all i did so far was set my voltage all the way and my fan to 100%. any tips to get me in the game would be greatly appreciated.
    thanks.
    Dec 2007
    Beneath The Remains, Greece
    I tested my DCUII and max i could get is 1260 on core running heaven all maxed. Havent tested ram yet. Normal oc for a 670 card, but its dead silent, even running fan at 70%, at an open case 30cm from my ear
    Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
    WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
    Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    I'm almost pulling the trigger on a GTX670, but I need some convincing. I'll be popping in on this thread from time to time.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    Dec 2005
    Philly
    Got my 670 GTX last Friday but haven't had a chance to play with it until tonight. Here is my initial results.
    Rampage IV Gene Bios 1305
    3930k @ 5000Mhz on Water
    16GB (4x4GB) G.Skill RipjawZ @ 2400Mhz 11-11-11-31
    Asus 670 GTX DirectCUII on Stock cooler
    3DMARK 11 with Boost clocks @ 1242/6696/2485
    3DMARK Vantage Performance - Boost clock screenshot below
    Vantage Run Boost clocks screenshot 1255/6750/2511
    4770K and 3770k
    MVI Gene and MV Gene
    2 kits TeamX 2400Mhz 2x4GB @ 2600Mhz 10-12-12--28-1T
    Asus 670GTX DCII
    Corsair AX1200 ~ Corsair TX850
    (2) OCZ Vertex 4 RAID0 ~
    Samsung BluRay Burner SH-B123L
    800D~EK Supreme HF Nickel~EK Coolstream 360~BP Matte Black Modded MCP655
    BP Mod Top V2~EK Res~Distilled Water~Silvercoils
    Apr 2004
    United Kingdom
    Not bad, that 3DM11 score makes me consider grabbing a GTX670 sooner rather than later as its a little over twice the score of my GTX460 so the £300 or so might be a worthwhile investment but I can't help feeling £300 is a touch steep for a GPU thats so cheap to make.. if it was £270ish I'd be all over it.
    "Prowler"
    Cooling:
    Dec 2005
    Philly
    That 3DMARK11 score is low, I only did that run as my first test before really pushing the clocks further. I spent most of my time running Vantage and scores were increasing pretty nicely with increase in clocks. I haven't hit a wall yet, just ran out of time last night. I didnt run 3DMARK11 with the highest clocks I ran in Vantage but will do so tonight.
    The above 670 GTX 3DMARK11 score is 176 points higher than my overclocked 560GTX Ti SLI best of 9945.
    Will spend more time on 3DMARK11 tonight to see how much higher I can go on air.
    Was going to get a 680 GTX but I am not dissappointed at all with the Asus 670 GTX DirectCUII
    4770K and 3770k
    Asus 670GTX DCII
  18. #18
    Apr 2004
    United Kingdom
    Hmm.. well you have a little challenge then. I have a odd 1GB GTX460 I've had kicking about unused for a year or more, if you can crack 12.5k in 3DM11 with your GTX670, I'll buy one
    "Prowler"
    Cooling:
  19. #19
    Dec 2005
    Philly
    12.5K 3DMARK11 just isnt going to happen. My score is 11th on HWbot and #1 is 11407
    4770K and 3770k
    Asus 670GTX DCII
  20. #20
    Apr 2004
    United Kingdom
    Unfortunate. The GTX670 could turn out to be rather limited then. We'll have to wait and see what happens over the next few months with driver updates.
    "Prowler"
    Cooling:
  21. #21
    May 2009
    France
    Quote Originally Posted by Ket View Post
    lol , in this case more interest for the 680
  22. #22
    Mar 2007
    My gigabyte 670 does +100 on the core wich is about 1260-1275 depending on the temp and memory does 1902 ( havent really tried more )
  23. #23
    Apr 2004
    United Kingdom
    Depends on the drivers and if nvidia have any performance left to unlock with the new GPU or if its a "thats all she wrote" story. If it turns out to be the latter it'll be a shame really.
    "Prowler"
    Cooling:
  24. #24
    Aug 2007
    Belgium
    Hi here,
    I bought the DCU II non TOP and i like this card a lot, it goes to 1333Mhz sometimes.
    3DM06 score:
    Kombustor score:
    Heaven 3.0 dx11:
    Uploaded with ImageShack.us
    In games, no overclock and it reaches 1110Mhz
    DiKKeneK fan !!
  25. #25
    Xtreme 3D Team
    Mar 2007
    Rio de Janeiro, Brazil
    EVGA GTX670 FTW
    Stock cooling and running turbo at 1285/7000
    [SIGPIC][/SIGPIC]
