Quick stupid question
I think I already know the answer, but just to be sure...
Is DDR3 memory compatible with slower speeds?
I'm putting together a Mini-itx Windows home server, using a Pentium G620 Sandybridge, and Intel DH67CF mobo.
The mobo supports 1066 or 1333 RAM, but I need low profile memory.
Managed to find some Corsair VengenanceLP for a good price, but it's the 1600 type. Will it downclock OK?
Thanks.
Desktop :-
AMD Ryzen 1800X | ASUS Crosshair VI Hero | 16Gb Corsair LPX | Asus Strix Fury | Corsair MP500 480Gb (OS/Apps), Samsung 850 Evo 1Tb (Steam), WD Caviar Green 2Tb (Data) | Lian Li PC-09 WRX | Superflower Leadex Platinum 1600W | Win 10 Pro x64
Notebook :-
Alienware M17x R4 | Intel i7 3630QM | 8Gb DDR3 | AMD Radeon HD 7970M 2Gb | Crucial M4 512Gb | Win 7 Pro
Media PC :-
AMD Sempron LE 1300 | Gigabyte GA-MA78GM-SH2 | 780G chipset/Radeon HD3200 | 2Gb OCZ PC2-6400 | Crucial V4 128Gb | LG GGC-H20L | Win 7 Pro
Storage :-
Windows Home Server 2011 | Chenbro ES34069 | Intel DH67CF | Pentium G620 | 4Gb Corsair Vengence LP DDR3 | Sandisk Ultra 120 Gb SSD (OS) | Highpoint RocketRAID 640 + 4 WD Caviar Red 2Tb RAID 5 (Data)
Thanks. Thought so, just wanted to double check before I ordered it.
Desktop :-
Notebook :-
Media PC :-
Storage :-
1066 and 1333 are JEDEC standard so it should work ok.
- You may not post replies
- You may not edit your posts
Forum Rules
