Here is the whole post with all the prototypes, Cad designs, blood sweat & tears.
I like your work man...when did you make new tec blocks?
混沌とした アンモラル
6 lbs of copper?!?!?!
Why yes, yes I do use Koolance..*Flame Wall Inbound*
I see plexi soooo...not 100% copper.
Circles SucQ!
heh, true. It was designed to be 100% copper, but in the end I didn't wanna hide the internals. So plexi it became :P
Yes, it is a hulk of copper. A bit excessive, but it was designed as a show piece.
And a little bit of rubber too if that counts against the 100% :P
Here is the build log if anyone missed it:
goo.gl/p2gGF
Just some machining shots from the second block. The outer shell is just rough bandsaw cut.
Here is a 1/2-13 bolt sitting on the GPU area after the initial rough machining of the back:
Block #2
Before O-ring:
After O-ring machining:
Blocks 2, 3, & 4 in various stages of completion
Great work but that thing would need vertical stabilizing rails off HDD racks/bottom of the case imo.
Putting that much weight on a PCI-E slot (even with two securing screws on the PCI areas) is a bit much.
Any performance data?
-PB
-Project Sakura-
Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
The motherboard will be stiffened by a dense foam used under it.
I got a 20°C or so reduction in load temps from the stock fan with Arctic silver alumina, a single triple rad, and 3 generic coolermaster quiet fans. Click on the original link for more info on the testing. The setup was pretty sub par, but that always leaves room for improvements.
I Love it It's nice to see a copper work of art. I'm so sick of all the nickle plated blocks.
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
Great polish !
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
