+ Reply to Thread
Results 1 to 20 of 20
Thread: GTX 690 block in the works?
    Ω ohms's Avatar
    Jun 2009
    Brooklyn, NY
    15
    Like the title says, will any company make a block for the Geforce GTX 690? I'm thinking of buying 1 or 2 of these and I definitely want them under water.
    Ω Raven Build Blog
    "The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
    " Inter Arma Enim Silent Leges" - In times of war, the law falls silent.
    Xtreme Guru Church's Avatar
    Dec 2009
    Latvia, Riga
    5
    I wonder what display setup you might have for their resolution to need 2 of those for quad sli .
    I'm pretty sure in few months we'll see 690 blocks from most of major vendors, EK, Swiftech (probably only preinstalled with EVGA cards), Koolance, DD, Aquacomputer, XSPC, Watercool, MIPS, Bitspower and so on ..
    Even though 690 predictably will be produced/sold in small numbers, to make blocks for it imho is mater of prestige, so with 90% probability they will be out there, especially when such blocks had been made for older dual gpu cards like 590/5970/6990. Just wait a bit.
    EDIT
    Meanwhile announcements are already out from EK, Koolance.
    Ω ohms's Avatar
    Jun 2009
    Brooklyn, NY
    15
    Well I currently run at 2560x1600 resolution on a 30" but I also have (3) Asus 24" LCDs collecting dust that I used to use for my Eyefinity setup.
    Current (well it's not quite current, I swapped out my Cinema Display LCD panel into my broken Dell 3007WFP).
    Old
    Ω Raven Build Blog
    Xtreme Member musicfan's Avatar
    Jun 2010
    Oregon, USA
    25
    Here is a review on the VGA card from Tom's. The 690 alone is $1000 US or 2x the 680. Will that change usual time-frame for blocks to appear?
    Cooler Master HAF 932 case; Corsair 850 tx psu; Dell 24" monitor
    XSPC rx rads; Apogee xt; gtx285+Danger Den block; mcp655's in EK-D5
    distilled water + silver in MasterKleer 7/16" ID on 1/2" barbs & compressions
    Ω ohms's Avatar
    Jun 2009
    Brooklyn, NY
    15
    Quote Originally Posted by musicfan View Post
    Thanks but I'm fully aware of how the card performs already I was just trying to see if this was something the water block manufacturers were going to make blocks for since it's more of a hard core enthusiast item.
    Ω Raven Build Blog
    Xtreme Addict paulbagz's Avatar
    Apr 2011
    North Queensland Australia
    237
    Major suppliers have always made blocks for these cards, don't see why this would be an exception.
    -PB
    -Project Classico- Worklog
    Intel QX9650 @ 4.14Ghz (460 x 9), Asus Striker II Extreme, 8GB Corsair Dominator GT (8-9-8-19-2T, 1840Mhz), 3x EVGA GTX 480
    3x 120GB OCZ Vertex 2 RAID 0, 2TB WD Caviar Black, Silverstone Strider 1200G, CoolerMaster CM 690 II Advanced (nVidia Edition), Acer GD245HQ
    Swiftech MCP655, MCR320-Drive, MCR220-QP, Apogee XT (Rev2), EK-FC 480s, Bitspower Blackfreezer 790i (NB/SB+Mosfets), EK-RAM Dominator, EK Triple Parralel Bridge
    Xtreme Member The Jesus's Avatar
    Jun 2008
    Winter Springs, FL
    15
    http://coolingconfigurator.com/step1...t?gpu_gpus=680
    Coming Soon
    ETA will be published under news section!
    Also,
    http://www.ekwaterblocks.com/index.p...t01returnid=17
    Expected early June.
    Why yes, yes I do use Koolance..*Flame Wall Inbound*
    I am Xtreme Koolance's Avatar
    Sep 2007
    Auburn, WA, USA
    0
    Xtreme Member bds71's Avatar
    Jul 2011
    Kaiserslautern, GE
    5
    i've seen remarks from koolance and EK stating they will have blocks for the 690 - haven't seen anything from the other big manufacterers, but i'm sure they will have something also. i am also looking for one (assuming i can ever actually FIND a real life gtx690) so i hope sooner rather than later
    i7 3930@4.5GHz (EK Supreme HF), GTX690@1.2GHz (Koolance NX-690), 128G 4M + 2x128G 4M raid 0, Silverstone TJ07, Custom Enclosure w/MoRa, 18x GT AP-31, 401X2 dual PMP-400
    Ω ohms's Avatar
    Jun 2009
    Brooklyn, NY
    15
    I ended up buying 2 670 Superclocked Editions since there were no 690s left in stock But thanks for the update Tim.
    Ω Raven Build Blog
    Xtreme Addict Boulard83's Avatar
    Mar 2009
    1
    Koolance released the 690 bloc.
    - Le Quebecois -
    - - - BTTB - - -
    EVGA X79 FTW - I7 3820 - PH-TC14PE - 16gb G.Skill 2133mhz - EVGA GTX 670 + Accelero TTII
    Tecnofront HWD BenchTable - Antec TPQ-1200-OC - 2x Agility 4 256gb - Surround Asus VE278Q 5760x1080
    - - - HTPC - - -
    Asus Z77-m Pro - 2500K - NH-C12P - 2x4gb G.Skill Ares 1600mhz
    Asus GTX 650 TI - X25-M 80gb - Enermax Naxn 550w - Lian Li PC-C60B
    - - - NAS/Server - - -
    Gigabyte H77m-D3H - G2020 - 2x4gb G.Skill 1600mhz - 2x 1TB Black - 1x 2TB green - CX430M
    Forum Quebecois, si tu parles francais !
    Registered User juanP's Avatar
    Sep 2008
    Los Angeles
    0
    Jul 2011
    Kaiserslautern, GE
    5
    "not in stock" ....anywhere....
    Aqua Computer Rep Shoggy's Avatar
    Apr 2008
    Germany
    0
    Took a while this time but our block is also ready now.
    Got a question or having a problem with your Aqua Computer product?
    Contact us via PM or E-Mail.
    Xtreme Member LeoAndrade's Avatar
    Nov 2010
    Brazil
    0
    awesome block! I like the "parallel" setup of the internals.
    PC: Sold everything
    Notebook: Asus G73jh [No GSOD, bios correction; No touchpad bug, tape correction]
    Greetings from Brazil!
    Xtreme Mentor Conumdrum's Avatar
    Oct 2007
    USA
    2
    Nice Tim! I like your blocks, no issues with the dreaded flaking. Using two 470 blocks long time and still working great. And your customer service for rebuild oring packs was awesome.
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Mar 2007
    SoCal
    4
    Any blocks in stock anywhere?
    Sig is under construction
  18. #18
    Crunching for the points! NKrader's Avatar
    Dec 2009
    Portlandia
    68
    Quote Originally Posted by LeoAndrade View Post
    yes very nice, aq always the best
  19. #19
    Sep 2008
    Los Angeles
    0
    yeah i liked the aqua blocks too, ordered them a month ago , never got them till date. need to file a complaint for refund. no more aqua stuff for me.
    went and bought koolance block, really happy with it.
  20. #20
    Jul 2011
    Kaiserslautern, GE
    5
    i ended up with koolance as well. not a big fan of nickel plating, but it was the *only* option at the time. no offense to koolance, but i had hoped to get an EK to match my other blocks (MB and CPU). it works well as far as i can tell - keeping both cores under 50C while under heavy loads. if it matched my other (full copper) blocks it would be perfect
+ Reply to Thread
