Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Thread: Silver and nickel don't mix???
    Oct 2003
    USA /okla
    Koolance's product warranty does not cover the use of 3rd-party coolants, coolant additives, or corrosion. Koolance LIQ-702 or LIQ-705 coolants are strongly recommended to help avoid issues with mixed metals or biological growth. Additionally, do not use aluminum with bare (unplated) copper or bare (unplated) brass in the same system. Do not use silver with nickel in the same system.
    Iam using distilled water with a komodo nickel/aceta 5870 block and a silver coil for algea control
    What could this do ??
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
    Apr 2005
    Silver and nickel are roughly (rather roughly) the same distance apart as copper and aluminum. While nickel is a lot tougher than copper, it's still a poor idea galvanically speaking.
    Apr 2012
    Melb, AU
    Yeh I used to recommend distilled and silver, now I say distilled and pt nuke.
    i7 4770K [L315B347]
    Gigabyte Z97 SOC Force
    F3-2600C10D-8GTXD | F3-2666C11Q-16GTXD
    GTX780 Epower2
    Corsair AX1200i
    TRUE Copper| Custom Water | Kingpin Venom 6.66 | Kingpin Tek-9 Fat
    i7 4770K [L312B515] | Asus Max VI Impact | 2x8GB Kingston 1600c10
    600GB WD Velociraptor
    GTX580 Classified
    Silverstone M600W Strider
    Coolermaster Elite 130
    i3 3225 | Asrock B75M Pro3 | 2x4gb Kingston 1333c9
    Intel 520 60GB | LSI 9211-8i | 6x Seagate 4TB
    Silverstone GD08
    Jan 2008
    Quote Originally Posted by AVulgarPicture View Post
    I'll just stick with still not recommending nickel
    Dec 2007
    Quote Originally Posted by Kayin View Post
    That's simply untrue...
    Nickle and silver are EXTREMELY close together on the galvonic series. They're both pretty noble metals.
    Apr 2005
    And yet we find that in systems with silver and nickel, they tend to shed nickel more readily than not. Is it a rash of everyone can't plate nickel, or is it an issue with corrosion (and there are instances where metals that are very close together can still corrode.) Once a pinhole gets in that plating, whether from poor plating or from corrosion, what have you then the nickel and copper themselves will have an issue with each other. It's simply best to avoid nickel.
    Dec 2007
    The real problem with nickel plated blocks is the lack of any and all surface preparation, and sub industry standard plating thickness.
    I too avoid nickel plated blocks. The only plated blocks I'd consider would be ones professionally plated.
    Silver is not the problem, it's the poorly done nickel plating.
    I am Xtreme
    Jul 2007
    Montevideo - Uruguay
    since use Bitspower TRUE SILVER barbs all my problems gone, 2 years using them now loops when take appart after months of use come clean as new
    24/7 - 5930K 46.5HT + ASUS R5E + DDR4 4x4GB 3100C15 1T + 2x 1TB SSD + 1x 3TB HDD + 4 SLI GALAXY GTX780 HOF + SEASONIC P-1200 all Water Cooled
    TRig - 4770KHT + ASUS M6E + GeIL 2x8GB 2666CL11 + GeiL Zenith 240GB SSD + GALAXY 750Ti HOF + CM 1200W + Raijintek Triton Liquid Cooler
    May 2009
    UK
    True silver barbs = BOLLOCKS ..... No Such thing as "True Silver", true silver is just another marketing ploy / gimmick and if they were "Pure silver" they would be to soft to be used as a barb ... True placebo ...
    Mayhems Lastest News -> https://www.facebook.com/Mayhems2009
    If you need to direct contact me its michael at mayhems dot co dot uk.
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Silver + copper here. I don't care for nickel plated stuff. Too much else to go wrong and it costs more anyway.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Apr 2012
    Quote Originally Posted by mlwood37 View Post
    Never held a .999 silver coin? It isnt soft.
    May 2009
    UK
    Quote Originally Posted by MattC View Post
    Coin silver is an alloy of 90% silver and 10% copper. Therefore its millesimal fineness is 900, also known as one nine fine. Most United States silver coins are made of coin silver.
    And for the full quote off another web site ->
    Fine silver (99.9% pure) is too soft to use in jewelry or almost anything else because it bends, breaks, and stretches too much. For this reason, manufacturing jewelers and silversmiths mix copper with it to give it some strength without discoloring it. Copper is the industry standard. However, some countries use other alloys as well.
    When you see “.999 fine silver” or “999” stamped on an item, it is considered pure silver. It is softer and more malleable than sterling silver. It is used in bullion bars, and is also known as three nines fine.
    Sterling silver (also known as standard silver) is what jewelry and silverware are traditionally made from, which is 92.5% silver and 7.5% copper. That is why you sometimes see .925 stamped on your jewelry. In the U.S., only a minimum of 92.5% fine silver can be marketed as “silver.”
    Sterling silver jewelry is often plated with a thin coat of .999 fine silver to give the item a shiny finish (called “flashing”). Silver will tarnish unless an anti-tarnish coat is added. Rhodium is sometimes used for this thin coat because it is very shiny and never tarnishes. However, rhodium is a very expensive option compared to the silver finish.
    Junk silver is an informal term used in the United States, United Kingdom, Canada, and Australia for any silver coin which is in fair condition and has no numismatic or collectible value above the bullion value of the silver it contains. Such coins are popular among people seeking to invest in silver, particularly in small amounts. The word “junk” refers only to the value of the coins as collectibles and not to the actual condition of the coins. Also, junk silver isn’t necessarily scrap silver.
    A silver-plated item has a thin coating of silver deposited onto a base metal which has a lower value than silver. Once used as plating, silver cannot be easily recovered, so it is of no value to those who are accumulating silver as an investment. EPNS means electroplated nickel-silver and is sometimes stamped on silver-plated items.
    .999 Silver coins ware down and are used as trade items and are not for general use (there a soft metal) because of this fact.
    As for Chinese silver well lets just say there is no standard and they don't just use copper so your guess is as good as mine what it contains.
    Technician
    Jun 2002
    Merseyside, UK
    So silver plating wont shed ions well enough to act as a biocide? I'd never considered there would be a difference between the quality of silver used to plate them and the .999 coils given they are marketed as a replacement for coils. I actually presumed it would be basically completely pure as it was electro plated silver ions?
    Jan 2008
    Try cutting a 3/16" thick slab of pure silver. It will wear you out!
    Case: Lian Li A71F
    Sys: 3930k, Sabertooth X79, G.Skill 2133Mhz 16Gb, (2x) GTX 680
    (2x) WD Black 1.5Tb, (2x) Crucial M4 - RAID 0
    Loop 1: Apogee HD, (2x) RX240, DDC3.2 w/EK v2 top, MCRES (R2)
    Loop 2: EK Full Cover (x2), RX360, DDC3.2 w/EK v2 top, MCRES (R2)
    Jan 2008
    ...They never claim the whole barb is pure silver "■Silver Plated from .999 pure silver" and "true silver" is just the name of the product so of course its a mraketing ploy. I don't think there are galaxies/auroras in your premixes but it still sounds nice.
    Whether or not the barbs in question work i don't know but if you are going to bash a product at least have a sound footing to start on.
    Apr 2005
    His footing is the fact that silver plating, silver pieces, whatever have far too little surface area contact with water to effectively create silver ions in the water, and they're in loops with less noble copper and brass, who are preferentially ionized, so that if you drained a loop with a silver coil in it you would get a small concentration of silver ions (from close contact with the coil/whatever) and much more copper ones (from the entire rest of the loop.) It's why silver used in the medical industry is in easily ionized substances, or else it's already broken down into microparticles. You could dose a loop with colloidal silver and it be far more effective, but the general reason you guys don't get issues with stuff growing in your loops is most likely your own care in putting stuff together and better sterilized water.
    I am Xtreme
    Jul 2007
    they do have a tiny layer of silver yes
  18. #18
    Jan 2005
    Now -I'm- concerned...
    I've got an all copper loop with a silver killcoil in it, but I do have nickel plated quick disconnects that route the hose to the outside of my case for my custom radbox. I've never even seen corrosion signs, and I'm using only distilled water. Recommendations? I could put some pt-nuke in it, if need be, but I do like the performance of pure water...
    Iwaki MD-20RZT
    Alphacooling Nexxxos UT60 with 6X Panaflo L1A's at 7v
    Dangerden MC-TDX with brass top.
    Koolance VID-NX680 nickle/acetal with Bitspower Chrome compressions.
    Koolance VL3N chrome quick disconnects on PCI backplate. (Yes, they leak)
    Custom extremely expensive super complex Tupperware res.
    Dangerden Fatboy fittings and Bitspower chrome compressions.
    About 5 feet of Tygon R3603 tubing.
    All built in a custom external wooden radbox, black.
    The computer changes all the time.
  19. #19
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    silver has an electro negativity of 1.93, nickle is 1.91, copper is 1.90, brass is 1.92-1.93 and aluminum is 1.61. you need a difference of ~0.25-0.3 to have galvanic corrosion so this is not anything about silver and nickle not getting along (silver and copper are further apart, and copper and brass are about the same apart.) the only reason that they have this is to void warranties, and to get people to buy their BS fluid that will clog blocks and is highly profitable.
    you were thinking of gold, it has an electro negativity 2.54, so you should not really mix gold with copper, but the gold will move to the copper so it wont be a problem, but then silver will move to nickle so that should also not be a problem, especially since you should put a nickle layer before putting silver on a part.
    5930k, R5E, samsung 8GBx4 d-die, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB , CM690II, swiftech h220, corsair 750hxi
  20. #20
    I am Xtreme
    Dec 2007
    so everything is good except aluminum really
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
  21. #21
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by Manicdan View Post
    yes, but also no chrome or titanium.
    look at the chart
    http://en.wikipedia.org/wiki/Electro...f_the_elements
    if the metal you want to use is under 1.70 dont use it.
  22. #22
    Jan 2008
    This is a much better argument and not the one he was making at all. I wasn't against his conclusion just the method to reach it.
  23. #23
    May 2009
    UK
    never been good at putting things into words . All though English is my main language its all so my nemesis.
  24. #24
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    Ive ran tap water with NO additive and just plain copper blocks for probably closer to a couple of years now... nothing growing so far. Last time i changed water was january, before that, maybe last summer...
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
  25. #25
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    I'm a solid copper advocate myself...
