+ Reply to Thread
Results 1 to 6 of 6
Thread: Help choosing between these 2 x79 boards please!
    NREMT-I newls1's Avatar
    Jul 2005
    near Atlanta Georgia (and hate it)
    0
    going to start my new build soon, and just trying to gather some needed info.. I have a budget for my next motherboard of 250-280$ and i think i've narrowed my choices down too one of these 2 boards..... Asus P9X79 or the Asrock extreme6 or extreme7.. Can someone please tell me which board might serve my purpose beter? My goal is the reach a OC with a 3820 of around 4.7ish 4.8Ghz would be awesome tho. Not looking for anything crazy, just something to tinker with and eventually have 2 7950's or 2 gtx670's to game with... Any input would be outstanding, and thanks
    **EDIT**
    Adding the Gigabyte UD5 X79 motherboard to my list too, really liking the reviews of this board!.....
    Nothing anymore
    Xtreme Addict OC Nub's Avatar
    Dec 2007
    16
    Of the choices given, I would have to go with the Asus board. I have an Asus X79, its been very stable at 4.8ghz.
    I also tried an Intel DX79TO for around 200.00 . Up to 4.8ghz it has also been an awesome board. It clocks the 3930k at 4.8ghz with very low vcore also very stable. It has no HS for the vrm's so I added some mosfet sinks to help cool it. It doesnt have some of the bells and whistles that more expensive boards have, but for the price I have no complaints.
    Xtreme Member RAYTTK's Avatar
    Jul 2008
    UK
    0
    As above - I have Asus X79 with 3930K @ 4.8. P9X79Pro IMO is a very stable board with a great price tag and no B***Sh** features your not gonna need for 24/7 use. I do have the EK mosfet waterblock tho and that keeps things much cooler than the stock heatsink.
    I think any you choose will be fine for 4.5 - 4.8 OC though so go for price or best RMA/customer service
    Asus P9X79PRO, EK MOSFET H20,
    3930K @ 4.8 Full Nickel HF Supreme
    2 X GTX480 EK Nickel, 4 x 4gb Mushkin 1600 @1.5v
    2 X Corsair GT 90gb RO, 3 x 640 WD Blacks Storage, Corsair AX1200, Phobya Nova 1080, Fesser 120,with GT 1850's
    Jul 2005
    0
    ok, thinking heavily on the UD5 gigabyte board.... hmmmmmmmmm
    Nothing anymore
    Nov 2009
    0
    What did you end up buying?
    All of those boards will do what you want, the only oddity that I know is the lack of BCLK Strap selection on the ASROCK, it does adjust it but you cannot do so manually, it does it automatically when you hit 100/125/166/250.
    i7 3820 4.9 / Rampage 4 Gene / 16B Mushkin 993997 / 2x 6870s CF / 2x WD Black RAID 0 / Samsung 830 SSD / HAF X with all fan spots full of radiators in push-pull / Rosewill 750 Capstone / Raystorm n MCW-60s / Singing along 24/7 100% loaded looking for the cure for cancer!
    Xtreme Member deachus's Avatar
    Dec 2005
    Philly
    0
    I have an Asus Rampage IV Gene running 4.8 @ 1.41v and love it. Great board
    Sent from my PC36100 using Tapatalk 2
    Qty 2 Core i7 3770k's with 2800Mhz IMC 5Ghz 1.41v
    Maximus V Gene
    TeamX 2400Mhz 2x4GB @ 2600Mhz 10-12-12-23-1T 1.65v
    Asus 670GTX DCII~NVIDIA 520GT
    Corsair AX1200 ~ Corsair TX850
    (2) 120GB OCZ Vertex 3 RAID0 ~ (2) 64GB ADATA RAID0 ~ (2) WD Cavier Black 2TB ~ (4) Seagate 7200.11 1.5TB
    Samsung BluRay Burner SH-B123L
    800D~EK Supreme HF Nickel~EK Coolstream 360~BP Matte Black Modded MCP655 + BP Mod Top V2~EK Res~Distilled Water~Silvercoils~Corsair H100
+ Reply to Thread
