LordEC: Posts "The GTX590 was barely faster than a 5970 (false) and could not compete with the 6990 (false)".
Rollo: Post links to some websites showing the 590 and 6990 traded benchmarks, depending on the game and that people liked it better due SLi vs CF and much quieter.
Others: "The reviews I read seemed to favor the 590"
MadMuppet:"Clearly Rollo is a liar!"
This is what is frustrating about these forums at times. Anytime AMD wins any benchmark, whether its WinZip for the Bulldozer or Shogun for the 6990, the AMD fanbase yells "Yaayyyy! AMD wins again! Why would anyone buy anything else?!".
I definitely prefer NVIDIA products, but I give AMD their due where they win, and I don't post anything inaccurate about NVIDIA products. (and if I did, I'd expect/hope to be corrected because i have no desire to have disinformation associated with me)
I stand by everything I've said in this thread and would like to see anyone prove otherwise. I'll also put up a bottle of Patron to the first person who wants to take the bet that AMD can't launch a 7990 with two full 7970 core at 1000MHz.
And if they can't, they're competing on price alone, as I've said all along.
Intel 990x/Corsair H80 /Asus Rampage III
Coolermaster HAF932 case
Patriot 3 X 2GB
EVGA GTX Titan SC
Dell 3008
Once you get past the Nvidia guided benchmarks from around launch day things get a bit murkier for the GTX590.
You are commenting about what is frustrating on these forums? What happened back in March?
Edit- You also are completely missing the point and turned this into a nice little sideshow.
Obviously you are very good at that while attempting to twist everything that is said.
Originally Posted by motown_steve
Every genocide that was committed during the 20th century has been preceded by the disarmament of the target population. Once the government outlaws your guns your life becomes a luxury afforded to you by the state. You become a tool to benefit the state. Should you cease to benefit the state or even worse become an annoyance or even a hindrance to the state then your life becomes more trouble than it is worth.
Once the government outlaws your guns your life is forfeit. You're already dead, it's just a question of when they are going to get around to you.
well said rollo
Its plain to see you prefer NV and NV makes a great product.
ATI 7970 is more of a overall product than the 680 since the NV card lacks computing and proper HDMI auto support.
Does the 7970 win some games yes does the 680 win alot of games yes. -- Less computing + 181 mhz core clock makes for a killer GPU.
One big problem is buying the 680 since in 2 months from release its near impossilbe to find one.
ATI had a 3month lead on the 680 but its looking like ATI is dragging its feet on the 7990 probly due to the issues you mentioned. If ATI does cut back some
computing processing and drops core temps to allow a dual 1Kmhz 7990 that would make for a killer card.
Time will tell thanks for your input
i7 6700K @4.8 ghz
XSPC RayStorm (very nice block)
Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
XFX-7970 with Swiftech Komodo nickel block
Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
Crossfire 30" decent monitor for IPS too bad SED tech died
Docsis2.0 Docsis3.0
-- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
I honestly haven't had any problems in regards to HDMI audio or video with my equipment... on either my 680s or my 670
I can pass audio to my TV direct no issue or to my amp as pcm or direct for DTS MA and Dolby HD. They work no better or worse than when I used my 5870 to do the same.
Feedanator 7.0
CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
i7 6700K @4.8 ghz
Docsis2.0 Docsis3.0
nV should drop the prices of their cards if they're going to leave that bug in there.
All along the watchtower the watchmen watch the eternal return.
I'm not quite sure what you are trying to say here?
I can play stereo audio on my TV via HDMI on my 670 as well as my previous 580. 5.1/7.1 works fine as both PCM and encoded formats on my reciever. I'm not exactly sure what the issue is The only minor disadvantage prior enthusiast Nvidia hardware had was lack of passthrough for Dolby and DTS studio formats. Even at that the difference between those formats natively and PCM is not perceptable whatsoever. Any decent media playback software with Bluray support will decode the stream and pass PCM to the reciever.
And for reference sake, I used a 5870 prior to my 580 and it didn't handle HDMI audio any differently for me than my 680/670 do now... ?
Feedanator 7.0
theres plenty of details already out
fact is nvidia hdmi reads the tvs EDID signal and for most tvs that means 2 channel sound only, even if the tv is set for passthrough, which could pass any signal through.
a simple override on nvidias control panel and it would be an issue. but that has been too much to ask for years now
2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
XS Build Log for: My Latest Custom Case
We're still to expect a GTX685 around Sept/Oct right?
Windows 10 - x64
Intel i7 3930k Sandy Bridge-E @ 4.20GHz
ASUS Rampage IV Formula
16 GB G.Skill Ripjaws 2133
2x EVGA GeForce 1080 Ti : SLi
Samsung 840 EVO
70'' Vizio @ 2160x3840
3x 30" Dell @ 2560x1600
ASUS Xonar DG
SteelSeries Arctis Wireless Pro
Not sure what a 685 would be, going off past product that nomenclature would mean a die shrunk 680, not happening afaik.
Work Rig: Asus x58 P6T Deluxe, i7 950 24x166 1.275v, BIX2/GTZ/D5
3x2048 GSkill pi Black DDR3 1600, Quadro 600
PCPower & Cooling Silencer 750, CM Stacker 810
Game Rig: Asus x58 P6T, i7 970 24x160 1.2v HT on, TRUE120
3x4096 GSkill DDR3 1600, PNY 660ti
PCPower & Cooling Silencer 750, CM Stacker 830
AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
2x2gb Patriot DDR2 800, PowerColor 4850
Corsair VX450
I think Natalia mean " 780 " .. not 685 .. Well the second generation .. or the BigK ...
Tesla GK110 is not waited before Q4 2012 and Q1 2013, this will be the first card to use GK110 it seems, so we shouldnt expect anything before, if the next "gaming" card is too GK110 based .
But Nvidia have allready surprise use by just release something at a moment we was waiting it a bit later.
CPU: - I7 4930K (EK Supremacy )
GPU: - 2x AMD HD7970 flashed GHZ bios ( EK Acetal Nickel Waterblock H2o)
Motherboard: Asus x79 Deluxe
RAM: G-skill Ares C9 2133mhz 16GB
Main Storage: Samsung 840EVO 500GB / 2x Crucial RealSSD C300 Raid0
Feedanator 7.0
just cause a receiver does everything now, does not mean everyone has a new receiver with 6 hdmi inputs. and some people do not even like it, they just want it to handle sound and let the tv handle video.
i actually had one that broke and the hdmi ports stopped working. (shipping it out was 50$, or driving 2 hours to the nearest yamaha service store, just not worth the effort) so i used my tv for inputs and an optical cable out to the receiver. thats how i found out about this nvidia problem. it worked just fine for my cable, ps3, ati card, laptops. the only thing that cant do it is my nvidia card.
i just bought a new onkyo on friday. and honestly some of the driving force was nvidias problem and it being resolved by me having to plug in an extra optical cable and switch it from pc to tv every time i wanted to watch a movie. but im not cheap when it comes to tv/stereo, and i still have a sony that is over 10 years old now and still works perfectly and it only got replaced by a bundle with some klipse speakers. so theres plenty of scenarios where hdmi is not provided/desired to be handled by the receiver.
Okay I see what you are saying now. I purchased an HDMI reciever explicitly to simply things along with a harmony one because I was tired of making everything more complicated than it should be. Honestly now though HDMI is the way to go for home theater assuming you have the appropriate hardware for it. Optical is far to limiting on a PC if you intend to play back non encoded content. Your stuck with stereo PCM unless you use a sound card with DDL or DTS Connect encoding ( which I used for like 4 years ) Not to mention this process tends to add enough audio latency that it causes a slight sync issue. It works and all but it was far some an elegant and trouble free solution.
Anyways... has anyone been able to get a 690 in their hands (without having to sell one of their hands in the process )
Feedanator 7.0
Try searching in regards to the issue with pass through related to TV's rather than the video card, there's allot of info on it now than when I was screwing around with it. I was reading that some of the xbox users where having the same issue with the TV's not passing through all the audio channels as well as other digital devices. They disabled something along the lines of automatic display detect on the devices which allowed the xbox to send 5.1 through the tv and pass through the optical to the reciever.
I haven't tried to get mine working after so long but you bringing the issue up got me a little interested about it again.
Maybe find out what chip Nvidia uses to send hdmi audio, AMD used to use the realtek I believe, maybe you can use manufacturer audio drivers which may allow forcing all channels out.
It's a stupid kink that shouldn't be so annoying to fix, Nvidia should allow forcing the stream and the TV's shouldn't be forcing the the gimping.
Corsair VX450
if it was stupid and simple, hours of searching across years of other people trying to fix it, i think i would have found at least one solution to try out.
this topic is kinda turning into a dead horse though. i dont really feel the need to keep discussing because its not longer affecting my situation.
Just randomly, can HDMI carry a better audio signal compared to Optical?
-PB
-Project Sakura-
Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
digital is digital.. most of the time.
The latest HDMI spec can carry better audio, AFAIK.
It can bitstream the new loss-less HD formats.
Member of Overclockers.com Folding @ Home team
"<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
Main rig:
AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
Secondary rigs:
Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
Toslink (optical) is SPDIF. SPDIF is limited to around 1500kbit/s bandwidth (the equivalent of 2 PCM Channels). This means that doing multichannel over SPDIF is always bitpacking with a lossy codec. To get true lossless multichannel you need HDMI out or good quality analog. For MC HDMI > Analog > SPDIF. For Stereo HDMI = SPDIF > Analog.
Main Comp (Win 7): ASUS R4E, i7-3930k @ 4.9GHz, G.Skill Ripjaw Z 4x4GB @ 2133MHz, ATI 6950flash/6970 Xfire, Custom Watercooling
3x Asus VW246H eyefinity; Polk Audio Monitor 40's (L,R), CS10 (C), Klipsch KG^4 (S), Sony STR-DA1000ES; all in a custom built desk
Server: (Ubuntu 11.04) i7-920 @ 3.8GHz, 24GB G.Skill
ASUS GeForce GTX690 $1199 in amazon
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
I just bought one for me, this is the best price i found
Gaming rig;
ASUS RAMPAGE IV BLACK EDITION
I7-4390K
G.SKILL Trident X 16GB 2400
Intel 530 240GB
2x Asus GTX780
Corsair AX1200
HP ZR30w 30
Win 8.1 pro
Sound rig;
Auzen X-Fi H.T. HD --> Yulong D100 MKII --> D-7100
Ah, yes, that is what I meant.
Sounds like that might be too far away for my tastes. Wanted to get 2 of those GK110's, but now I will debate between two 680's or three 670's. I have a feeling that two 690's wouldn't be worth it, even at 2560x1600. I think my current quad-fire setup has caused more headache than it was worth, not to mention games like Skyrim had a 2 GPU limit anyways. lol
Windows 10 - x64
Samsung 840 EVO
ASUS Xonar DG
Xeon W3520 @ 4.0Ghz ~ 3x 7970 ~ 12GB DDR3 ~ Dell U2711
