Distributed Computing: Making the world a better place, one work-unit at a time.
http://www.worldcommunitygrid.org/index.jsp
Ok now curiousity has the best of me. What is it about this board that has you so excited??
Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
Cruncher #3: 8-core Xserve 1,1
T400 for non-crunching
"But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
Well my HTPC all started with an AMD Athlon X2 BE-2400 on an Asus M3A78-EM mainboard (2009ish i think) and it was supposed to be uber low power yet the best at a media center setup (hardwarewise) and then I got hooked up with a Phenom X4 940 to help out with the sluggishness of the BE-2400, which made the 780G graphics shine (for once). A year ago I bought the P8H67-M Evo and an Intel 2600k but it for whatever reason ran REALLY hot (like for serious hot) on stock cooling without any significant load. I originally RMA'ed the 2600k and its replacement ALSO ran hot as can be. So I thought it might be the board, and ended up buying an Intel Boxed board (this week) to settle my curiosity, and its also reaching into 80°C or higher when running prime95.
So im basically done with trying to figure out what is the problem with this setup, but I want to crunch with all my systems, and this one won't let me, so im getting rid of it. The P5Q-EM is the magical answer, and it will allow me to use Loonym's old Q9650 in it with my AWESOME Swiftech MCX-Vcore heatsink (http://www.swiftech.com/mcx-vcore.aspx). Mind you, Loonym's quad core should always be crunching
for the glory of bardob!
It might just be me, and I see where you're coming from, but if a board isnt designed to handle 100% load for a significant period of time, then it should not be made in the first place. I'll admit that this is a desktop board, not a mission critical piece of infrastructure. However, it not being "designed" to handle the load of the processor it supports just sounds completely counter-intuitive to the industry. Cooling and air movement will not be a problem at all. I used to run a Dell Optiplex workstation with a quad core proc in it, crunching 24/7 for months at a time!
maybe I am missing something?
That's always a good idea, especially around the mosfet area of the cpu.
Looks like i should have jumped in that P965 drawing Doh! Off to ebay for a board.
i3-8100 | GTX 970
Ryzen 5 1600 | RX 580
Assume nothing; Question everything
It's like 2006 in here.
Thanks guys. Now I need to go frantically dig for that DP 771 socket board and see if it works.
That was fast shipping shoota!
i3-8100 | GTX 970
The 3770 is crunching
It still needs a better cooler as it is running a little hot now(65-70c). And a nice small case to fit it all in to. That can all be done later. I just had to get it up and crunching ASAP.
With every thing at auto it is now running at 3.7 GHz and uses just 100 watts.
Thanks again, Blake.
so im lookin for a s775 quadcore to stick in that mobo that i won im gona be giving to my little brother and its gona be cruncher
anyone have a decent one for sale? lookin to spend about 70$ if that.. q6600 would be good.
figured id post here sense it was relevant.
EDIT:
and some decent looking ddr2 with fun heatspreaders, 1066 flavor, at least 4gb favorably 8gb..
