I have an AI7 board running at the spec in my sig. If I changed my default NB cooler to an after market one what would I gain?
Also any suggestions on a NB cooler?
Thanks!
Thanks!
It all depends on the mobo, some dont really care of the heat, but some are hating the heat, but a new NB cooler cant by bad![]()
I guess it would increase your clocks as nb is preety important.
on 875 boards you only need them above 300fsb afaik...
on nf2 boards above...180fsb lol
Its a perspective question.
If you plan on overclocking to a heavy extent...yes, I would change the NB stock cooling.
If you are only thinking of going a little past what the board officialy supports, not worth the money.
I like my women the way I like my processors...naked.
I am not the HellFire that writes bios files. I work strictly on voltage modifications.
well I only run it tops at 240FSB.
Most of the time at 230-235.
Which ones do you guys suggest?
hmm here i can run 300fsb on my 865, i didn't open it and put some ceramique, the board is 100% stock
PS: here is very hot
P4 2.4 M0@3.7 | IS7-E | 1GB OCZ4200 | WD SATA 200GB | AIW9800PRO
Toshiba 5205-S705
