beats me
left is return tasks. avg was like 1hr. right is what i woke up to this morning on the 3770k. 100 results out of my total of 161. my HCC seem to be all running high priority
Intel C2Q Q9550 2.83ghz :: Intel DQ45CB :: 4 x 2gb OCZ DDR2 PC2-8500 Reaper HPC :: ASUS EAH5850 :: Thermaltake TR2 RX 750w :: Western Digital Caviar Black 4 x 750gb in RAID 10
Intel e3-1235 3.3ghz :: Intel s1200kp :: 4gb kingston hyperX 1600mhz :: WD 500gb Cavier Green
Intel i7-3770k 4.4ghz :: msi z77ma-g45 :: 8 gb patriot Signature 1600mhz :: 160gb WD Cavier :: 5830 + 5870 CF :: Antec Earthwatts 650w
"...all men die, and no brave man lets death frighten him from his desire..."
IVY having a bigger affect on WCG than we though?
Here is my 2600K at 5.0GHz
http://stats.free-dc.org/stats.php?p...hostid=1678266
And on that note... no one made a list totaling everyones score for the week like last year?
Yin|Gigabyte GA-Z68X-UD5-B3|Swiftech XT -> GTX240 -> DDC+ w/ Petra's|2600K @ 5.0GHz @1.368V |4 x 4 GB G.Skill Eco DDR3-1600-8-8-8-24|Asus DirectCUII GTX670|120 GB Crucial M4|2 x 2 TB Seagate LP(Raid-0)|Plextor 755-SA|Auzentech Prelude 7.1|Seasonic M12-700|Lian-Li PC-6077B (Heavily Modded)
Squire|Shuttle SD36G5M| R.I.P.
We've got a list of the top 20, but sadly you're like me... somewhere between 20 and 30.
And yeah... I'm thinking there might be more to Ivy... gonna wait for some more numbers (actually I can't afford to add an ivy atm, so yeah...)
I meant for just this past SC week.
keep asking me. ill give you what ever info i can. I dont want to shut it down tho
GFAM takes 5 hours =\ really slow and really slowing me down
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
i did
162 tasks, mainly cause GFAM slowed me down. but points also down. same reason?
Some project score better or worse than others, it's not consistent across all WCG projects. I found HCC scores well compared to most others but Say No to Schistosoma if off the charts. This is for Linux of course and may not apply to Windows or Mac. Of the two projects shown above GFAM is returning more per hour (39pph) than HCC (35pph). A bigger sample of GFAM units would help confirm or refute that. So far it looks to me like GFAM is returning BETTER than HCC so if you're just after a higher points output then killing all your GFAM units just shot you in the foot. If your goals are different then it would help to know what you're after.
[SIGPIC][/SIGPIC]
i suppose. never tried schistosoma
should have replied before movieman. hes feeding bad advice in the loop ;p
If he is it's not deliberate. Like I said, it would help to know exactly what you're looking for in the numbers and what you goals are. If you're trying to get the highest number of completed results then HCC is the way to go. If you after points then possibly not. If you're after the highest return on a specific project then that's different again.
[SIGPIC][/SIGPIC]
My 3770k @ stock (3.7GHz turbo) this past week got an average of 44.5k wcg points with Computing for Sustanaible Water using 85-88 Watts.
No overclock numbers tough, it's on an Asus P8H77-I mini-itx that will be used as a media server on a Fractal Design Array R2 case.
It has a Ocz Agility 3 120GB SSD and 8GB G.Skill DDR3 1600 Ripjaw X kit, so the power numbers at full cpu use, seem very good.
HMMM.. Say it's 100W here in the USA on 120v..
Damned impressive.
Can someone here in the USA with a 3770K stick a kill-a-watt on it at defaults and also list your PSU and anything else that draws electrical attached?
Also list idle and 100% WCG loading..Thanks
I'm using the 300W SFX PSU that comes with the case, it's 80 plus certified.
Also using a Noctua NF-F12 fan on the heatsink (0.6 Watts), and remember that it's a mini-itx H77 board, it will obviously use less power than other boards.
Anyone here knows what's the turbo speed on the i7-3770 non K for the full processor use? (Not the 3.9GHz single thread, but full processor working) Here it's about 40€ between the normal 3770 and the K version.
No, the 3770 has a 3.4GHz speed base, while the 3770K has a 3.5GHz speed base.
That's why i asked if anyone knows the turbo speed for the 3770 full processor use. I wanted to know if it's 3.6GHz or 3.7GHz like the K version.
