Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 116
Thread: Intel 22nm 'Ivy Bridge' Core i7 3770K Reviews
  1. #76
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by Manicdan View Post
    and then how did they get 4.8ghz on air with IB while the rest of the world seemed stuck at 4.5-4.6
    Most got to 4.7-4.9 before becoming temperature constrained.
    Donate to XS forums
  2. #77
    Xtreme Guru
    Aug 2007
    i checked it out and i do not like the OC results for power consumption.
    4.8ghz on SB should not take 1.48v
    I didn't see mention of their IVB voltage either.
  3. #78
    Apr 2005
    Calgary, AB
    Was thinking the same thing. There is a whole section..
    Quote Originally Posted by SKYMTL View Post
    Read ours. We dinged it no less than 10 times in our article, and with good reason.
    MB Reviewer for HWC
    Team OCX Bench Team
  4. #79
    Apr 2008
    Another +1; ours talked about it as well.
    [XC] gomeler - Public note: If you PM me to tell me that I am disrespectful at least have space in your PM box so I can tell you I don't care.
    [XC] gomeler - I come to the news section to ban people, not read complaints.
    I heart gomeler!
  5. #80
    I am Xtreme
    Dec 2007
    its at the end. 1.28v
    EDIT, 1.27v sorry
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
  6. #81
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Quote Originally Posted by R101 View Post
    Any iGPU overclocking articles?
    Mike and I both did iGPU overclocking. UD3 and Gene V
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
  7. #82
    Aug 2005
    Quote Originally Posted by FUGGER View Post
    Thanks, I will check it out. Quick sync is more important to me than 5-10% cpu speedup.
  8. #83
    Feb 2007
    I don't understand the purpose of quicksync. It has worse quality and speed compared to x264 --ultrafast preset.
  9. #84
    Jun 2007
    Did you do any iGPU + memory overclock bencharking?
    Plase share the link,
    Thanks,
    bruno
  10. #85
    Xtreme Mentor
    Feb 2007
    West hartford, CT
    i think semiaccurate did an article on igpu overclocking, conclusion it didnt gain much
    id be more interested if somebody donated their cpu to the cause and took the heat spreader off and then OC'd it see if that helps with heat disapation
    FX-8350(1249PGT) @ 4.7ghz 1.452v, Swiftech H220x
    Asus Crosshair Formula 5 Am3+ bios v1703
    G.skill Trident X (2x4gb) ~1200mhz @ 10-12-12-31-46-2T @ 1.66v
    MSI 7950 TwinFrozr *1100/1500* Cat.14.9
    OCZ ZX 850w psu
    Lian-Li Lancool K62
    Samsung 830 128g
    2 x 1TB Samsung SpinpointF3, 2T Samsung
    Win7 Home 64bit
    My Rig
  11. #86
    Jan 2005
    Quote Originally Posted by Boogerlad View Post
    According to Anand, QS is 2x faster then Handbrake with acceptable image quality.
    http://www.anandtech.com/show/5771/t...770k-review/21
  12. #87
    Feb 2007
    I don't see any screenshots of the x264 encode. And where is the original pre encoded screenshot?
  13. #88
    Mar 2009
    I dont understand the purpose of this post with no benchmarks and proof
  14. #89
    May 2008
    Sydney, Australia
    Quote Originally Posted by tbone8ty View Post
    id be more interested if somebody donated their cpu to the cause and took the heat spreader off and then OC'd it see if that helps with heat dissipation
    +1 on the IHS exercise
    I think:
    1. There must be a bigger-than-usual thermal resistance bottleneck between the IB die and the IHS. IB apparently draws less power than SB at the same clock, yet its on-board thermal sensor says it runs hotter with the same cooling setup. Assuming that the thermal sensors have the same accuracy, the laws of physics say that for this to happen, our external heatsink must run cooler when on IB. Has anyone checked? (Putting an ordinary thermometer in the airstream downwind of the HSF would tell us).
    2. [[I have an idea that]] Someone posted in another thread that the IB chip is not soldered to the IHS and uses some yucky old TIM instead ([Edit]: http://www.xtremesystems.org/forums/...preader-Report[/Edit]), in which case it may be comparatively easy to remove the top of the IHS. Hopefully you wouldn't need to electrically insulate the top of the chip from the external HS that you'd then install.
      Maybe try removing the IHS from a dead chip; next level would be to do it with the cheapest IB chip available.
      If the problem is due to the surface of the silicon being microscopically rough instead of flat as with conventional 2-D transistors, removing the IHS may not help much though.
      Sorry, but I don't have an IB chip dead or alive, or a sponsor, or a Newegg or a Microcenter or anyone else who will sell me an IB at a cheap price.
    @hokiealumnus: Thanks for your review. Re the temperature of IB vs SB, what no-one else has suggested is that if you want to state a % difference, you should be talking about the rise above ambient. That eliminates the problems with quoting above absolute zero, and also cancels out the differences between the Fahrenheit and Celsius scales.
    And those of us who are looking at these chips not for gaming, benching or personal status, but to contribute to grid computing projects such as worldcommunitygrid haven't had much of a say here yet. We need high CPU processing output per watt and long CPU life - up to 5 years - at the highest speed that is compatible with those constraints. It's disappointing that IB does not seem to enable that speed to be pushed much higher if at all, but the saving in power consumption is significant.
    I'll wait a month or 2 to see whether bugs appear in the new architecture or whether any improved steppings come along, then upgrade to IB. I have a very sick 2600K that is hanging onto life by a whisker at 4.2GHz and its max Vcore without further degradation of 1.23V and memory at its max stable clock of 1066MHz , plus a couple of 45nm C2Qs that are great machines but they've gotta go, in the face of imminent huge increases in electricity costs here.
  15. #90
    Mar 2009
    blindfreddie, it is hotter with less voltage because the chip is smaller. the IHS is probably really well made and fastened on. it is just a curiosity that removing it and directly connecting to something else might help.
  16. #91
    Aug 2005
    I use 2600K (about 30 of them) right now.. You can check the quality of the encoding in the Anandtech original SB article.
    The speedup that IB brings to the table (at least in my usage scenario) is just amazing. And Haswell cannot come soon enough .
  17. #92
    I am Xtreme
    Sep 2006
    That's why they are called Semiaccurate :p I got good gains with IGP OCing and faster Ram (2600 vs 1600Mhz) in some games...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
  18. #93
    Xtreme Mentor
    Jun 2008
    France - Bx
  19. #94
    Mar 2010
    Istanbul
    old bartons were 101mm2 and 75W doesnt have the problems like ivy.. i could make it stay cool under 2500MHz like 65-70C.. it should be near drawing 150W or so and even smaller diesize than ivy relatively..
  20. #95
    Sep 2007
    Quote Originally Posted by kaktus1907 View Post
    With much lower currents though.
  21. #96
    Mar 2010
    Istanbul
    Quote Originally Posted by Cold Fussion View Post
    that's my point.. i dont buy what everyone says oh it's such a smaller die size that hsf cant cool it blah blah.. we had/have much smaller and similar power draw consumption numbers various chips that this wasnt the case until ivb but now everyone says that..
  22. #97
    Xtreme Mentor
    Jun 2008
    France - Bx
    - Sandy Bridge : 0.87 watts per mm²
    - Ivy Bridge : 1.11 watts per mm²
    The decline in consumption is not large enough compared to the size reduction of core, Ivy Bridge is more difficult to maintain in temperature.
    http://www.hardware.fr/articles/863-10/temperature.html
  23. #98
    Jan 2005
    This comparison doesn't make sense. Bartons didn't have precise integrated temperature sensors, so you don't really know what temperatures happens inside the chip.
  24. #99
    Apr 2008
    Quote Originally Posted by BlindFreddie View Post
    Thank you for that; and you're absolutely correct; I didn't mention that but absolutely should have. Ambient was very close to the same between the two within two degrees Celsius. I'm kicking myself for not measuring when I took it, but that room stays very close to 23°C, ticking a degree or two one way or the other (except in the middle of summer, when it can heat up more).
    I heart gomeler!
  25. #100
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    Interesting information
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
