Lots of love to swiftech for making pretty looking fittings(and all of there other great product). But please stop with the horse
If that piece of paper was true in any sence, i would have experience daily leakage or something silly.
I always hand tighten my fittings (feser,koolance,bp) and bend my tubes like they naturally bend, if you dont do that, yes they will/might loosen the fittings, but if your such a big idiot, you deserve nothing less.
Swiftech is basically advertising that they invented something new, its not 1995 where we all go teflon on our fittings. And since its 2012, who the
uses tools to tighten a fitting? Install blocks and fittings and tubing on components before you put your hardware in your case, and its done.
This hobby requires some common sence, and a big fat wallet. If you dont have both, your not ready for it. <--- that should be the entire manual!
