+ Reply to Thread
Results 1 to 8 of 8
Thread: Screwless reservoir mounting
    Registered User JudgmentJay's Avatar
    Dec 2008
    Texas
    0
    Hello,
    I have an EK Multioption RES X2 250 Advanced reservoir, and I'm going to be using it in a loop in a CaseLabs T10 case. Unfortunately, the area where I want to mount it (next to the motherboard tray) has no screw holes. Does anyone have experience using other things, such as double-sided tape (I was thinking this product in particular), to mount the reservoir clamps? It seems like a viable option, but I'm worried about the tape ripping the paint off of the case should I ever need to remove the clamps.
    Hardware: CaseLabs T10 | REIV | 3930k @ 4.8 | 16GB Mushkin 1600mhz 8-8-8-24 | 3x GTX680+ 4GB Tri-SLI | 2x 240GB Cherryville raid0 | 2x 3TB Barracuda | CEntrance DACmini CX | HiFiMan HE-500 | 30" Ultrasharp U3011
    Watercooling: EK-Supreme HF | 3x EK-FC680 GTX | EK-FB Kit RE4 | MCP35X2 | 2x Alphacool UT60 | XSPC RS360 | EK-Multioption RES X2 250 Advanced
    Xtreme Enthusiast mav2000's Avatar
    May 2009
    22
    Don't use the foam tape. Use 3m double sided industrial strength tape. Will hold much better and does not pull off the paint. Now wether it can hold on with the res filled is something you will have to see for yourself as the clamps for that res have a small base so there may not be enough surface area. I would suggest you drill a hole and use tge screws
    Xtreme Member basserdan's Avatar
    Jan 2008
    1
    what mav2000 said + occaisionally apply a little pressure to the mount over the next 24hrs and that tape will hold very well. Eventually, it wind up to where you will have to scrape it off. WIPE BOTH SURFACES WITH ALCOHOL FIRST.
    Case: Lian Li A71F
    Sys: 3930k, Sabertooth X79, G.Skill 2133Mhz 16Gb, (2x) GTX 680
    (2x) WD Black 1.5Tb, (2x) Crucial M4 - RAID 0
    Loop 1: Apogee HD, (2x) RX240, DDC3.2 w/EK v2 top, MCRES (R2)
    Loop 2: EK Full Cover (x2), RX360, DDC3.2 w/EK v2 top, MCRES (R2)
    Xtreme Addict wez's Avatar
    May 2004
    Aland Islands
    25
    Or, drill a couple holes?
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
    Xtreme Member AVulgarPicture's Avatar
    Apr 2012
    Melb, AU
    1
    Yeh. I'd just drill the holes. Measure ten times, drill once.
    i7 4770K [L312B460]
    Gigabyte Z77X-OC
    F3-2600C10D-8GTXD | F3-17600C7D-4GBPIS | F3-16000C9T-6GBTD | F3-2666C11D-8GTXD | PVV34G2500C9K | TXD38G2666HC11CDC01
    GTX580 SOC | 8800GTX | 8800GTS (320/640)
    Enermax Revo85+ 1250w
    Custom Water | Kingpin F1EE Dark | Kingpin Tek-9 Fat | Kingpin Ney Pro
    i3 3225 | Asrock B75M Pro3
    10x Samsung F4EG 2TB
    Silverstone M600W Strider
    Silverstone GD80
    Xtreme Member gr1p's Avatar
    Dec 2010
    Corona, CA
    0
    +3 on driling some custom holes.
    If the full res falls and takes out your system...itll be a bad day.
    motherboard - EVGA Classified e770 EK watercooled
    cpu - i7 950 @ 4.420GHz EK watercooled
    video - EVGA gtx 580 sli 950/1900/2300 EK watercooled
    memory - 3 x 4GB Mushkin Redline (7-8-7-20 1T)
    storage - Corsair Force 120GB ssd
    power supply - Corsair AX850 (MDPC-X sleeving)
    case - Danger Den Torutre Rack
    Dec 2008
    Texas
    0
    Alright, you've talked me into it. Never done anything like this, so wish me luck!
    Apr 2012
    Melb, AU
    1
    i highly recommend pilot holes.
    i7 4770K [L312B460]
    Gigabyte Z77X-OC
    Silverstone GD80
+ Reply to Thread
