+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 39 of 39
Thread: ivy With Biostar TZ77XE4
  1. #26
    Xtreme Member tom1's Avatar
    Sep 2008
    Italy
    0
    great bench and score bro
    http://www.xtremehardware.com/
    The Best Scene of Hardware In Italy
    Follow Us And Add Me http://www.facebook.com/?ref=tn_tnmn...00003658778509
  2. #27
    Xtreme Guru trans am's Avatar
    Jul 2004
    7
    eyegoo! nice namegt. I just bought the xe3 today. is the xe4 worth the extra $? I only see it has some more sata ports and better quality audio chip and a heatpipe. Any other major differences between xe3 and xe4?
    thanks for the xe3 mod Pt1t .
    Im excited to play with this thing.
  3. #28
    Xtreme Enthusiast namegt's Avatar
    May 2008
    Seoul, Korea
    0
    Xe3 mod
Size:  211.7 KBName:  DSC_2898.jpg
Size:  225.7 KBName:  DSC_2899.jpg
    NAMEGT- Xtremesystems
    http://www.playwares.com
  4. #29
    Jul 2004
    7
    crap this XE3 mod is scary for me as I am a total noob with the soldering iron. is there anyway I can go around to the mobo hole to the back of the board instead of drilling through the pcb? I took the south bridge sink off to reveal what the blue wire is going into. I still dont get it. what is the red wire going into? can you give me some help here? Im new to all this. I miss the clarksdale mod when we would just draw a conductive pen line. I havent overclocked in 2 years and I just want to get this right the 1st time.
  5. #30
    Jul 2004
    7
    would this work?
  6. #31
    I am Xtreme sin0822's Avatar
    Dec 2004
    France
    50
    i think it is much easier to solder to that pad rather than solder to the little pin.
  7. #32
    Jul 2004
    7
    sin help my noob arse out. What do you mean by pad. see image and please tell me what you mean by pad. I havent overclocked in 2 years. the last 3 hours have been spent getting all my overclocking crap organized. we need a thread called "how to organize your overclocking crap"
    I have some solder flux and a regular pin point solder tip. can you point me to a link that has a solder tip that would be better for this? what do you guys use for mods like this? Ive always wanted to learn how to mod properly but the xtrememods page is dated and I think its time for a thread like this. If you show me how to do this I will gladly make a mod step by step biostar cold mod.
  8. #33
    Jul 2004
    7
    Guys, I love biostar but I think I dont have the skills to mod this board without damaging it. I'm gonna send it back to newegg and exchange for something like Max V gene or something. I jsut cant afford to screw this up. If you guys have any suggestions let me know. I want to keep it around $150. The main goal for me is a board that can handle cold well with doing minimal mods. the th55xe clarksdale board was amazing and all it needed was that conductive pen mod on the cpu. I miss those times.
  9. #34
    Registered User toyone's Avatar
    May 2008
    Hungary
    0
    Hy.
    How to set higher CPU voltage? Me TZ77XE4 max 1.8v.
    Use latest BIOS Z77CF419
    Sorry for my bad english...really
    Xtreme 3D Team Hungary
  10. #35
    Registered User Highgertz's Avatar
    Aug 2008
    0
    namegt
    Salut, share for the BIOS 03/27/2012, thanks in advance.
  11. #36
    May 2008
    Hungary
    0
    Yesterday for the first time I tested ivy bridge.
    System Spec
    Biostar TZ77XE4 @ EFI 419 max 1.79v vcore
    Intel i5 3570k @ LN2 Ryba Semi POT
    G.Skill ECO 1600Mhz CL7 1.35v
    Corsair F120 120GB
    Enermax Modu 87+ 800W
    Gigabyte GTX260 192sp & MSI HD7970
    No Mod.
    No CB / CBB
    2D
    Maximum valid 6300Mhz 4core, corrupt valid, 6200Mhz ok
    SuperPI 1M 05.857ms
    SuperPI 32M 5min 28sec 610ms
    Pifast 11.83sec
    3D
    3DMark05 - 54369 marks - Radeon HD 7970 @ 1275/1859MHz
    Aquamark - 455356 marks - Radeon HD 7970 @ 1300/1900MHz
    I forgot to save valid file.
    Aquamark - 405908 marks - GeForce GTX 260 192SP @ 745/1250MHz
    SuperPI 1M & 32M, Pifast, Aquamark(HD7970) & 3Dmark05(HD7970) new hungarian record.
    Thanks to:
    Biostar, Cédrus Kft.,Corsair, 04ahgy, subaruwrc.
    toyone
  12. #37
    Xtreme Addict Alex-Ro's Avatar
    May 2007
    Romania
    13
    new bios 515 is out,anyone knows of new pcb revision of this board that would fix that pll bug?
    http://hwbot.org/forum/showthread.php?p=174103
  13. #38
    Aug 2008
    0
    nothing is fixed, power-saving mode operates fully
  14. #39
    Aug 2008
    0
    Biostar TZ77XE4 CPU PLL MOD - i have refused to work, the motherboard has not started... without it works.
+ Reply to Thread
