I am upgrading my GTX285's to a GTX680, I want to hang onto one card to use as a dedicated physX card.
I have a hydro copper water block, is is ok to flash the firmware from a faster card? Does evga bin these?
[Intel core i7 4820K..........Asus Rampage IV Black Edition] LAN Parties attended:
[512GB Samsung 840 PRO 512GB......2xWD Black 7200 2TB RAID0] FITES [fites.net] 2012, 2011, 2010, 2009, 2008, 2007
[32GB G.Skill DDR3 2400 4x8GB....2xEVGA GTX780ti Classified] L'Pane NorEaster [lpane.net] 2010, 2009, 2008
[Corsair 900D.......Primochill CTR 250......Corsair AX1200i] Quakecon [quakecon.org] 2010, 2009
[MCP35x2.........Swiftech Apogee HD......Swiftech MCR420-XP] PAX East [east.paxsite.com] 2012
I flashed a stock evga gtx460 to a gtx460 ftw. Worked just fine, no issues at all.
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
I believe GTX285 thats allready work on max.
If you put in on faster clocks it may overheat and life will be much shorten
True, full water block only for gpu? Or to all gpu and mosfets and memory chips too?
i doubt its gonna be a problem
but if it cant handle the higher clocks just flash back
btw ftw cards are better binned than even the oc ones
maximus IV extreme gtx580
gigabut p67-ud7
p67 sabertooth
2500k+2600k
antec 1200watt
EVGA classified 760
920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
OCZ3RPR1866LV6GK hypers
dfi ut p35 rampage extreme
gigabut p35c-ds3r bios suks
gigabut x38-d6q dead thank god
ballistix 8500 1240mhz@2.02v
I found the FTW BIOS for the GTX285, but couldn't find a hydro copper. Both run at the same speeds, if this fails (I doubt it will) I'll go with the SSC BIOS.
Thanks for the input.
