Results 1 to 11 of 11
Thread: where are the PCIE thunderbolt add-on cards for PC?
    I am Xtreme
    Jan 2006
    Australia! :)
    Question where are the PCIE thunderbolt add-on cards for PC?
    as per title - anyone know if they exist?
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    heatware / ebay
    HARDWARE I only own Xeons, Extreme Editions & Lian Li's
    https://prism-break.org/
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    they wont be out for a year or 2 if they even come out. can i ask why you would even want thunderbolt at this point, there are no devices that are TB only and it will be a dead platform soon once light peak optical is out.
    5930k, R5E, samsung 8GBx4 d-die, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB , CM690II, swiftech h220, corsair 750hxi
    I am Xtreme
    Jan 2006
    Australia! :)
    Quote Originally Posted by zanzabar View Post
    http://www.blackmagic-design.com/pro...ensity/models/
    I want the Intensity Extreme.
    heatware / ebay
    Jul 2007
    SF bay area, CA
    the pro is the same as the extreme but internal, why not get that if you are looking at a TB card.
    the extreme is also OSX only, but that may be since there are no consumer TB windows computers.
    I am Xtreme
    Jan 2006
    Australia! :)
    check the specs page, they are not the same - the extreme has 1080P50 & 1080P60 IN capabilities - the other 2 don't
    heatware / ebay
    Jul 2007
    SF bay area, CA
    this page says that nether do 1080p50 or 60, only the TB shuttle dose and that is still OSX only.
    http://www.blackmagic-design.com/pro...ity/techspecs/
    and that stuff also has a composite 4:2:2 color space
    I am Xtreme
    Jan 2006
    Australia! :)
    dude..go read it again, your eye sight is failing you
    heatware / ebay
    Oct 2006
    Quote Originally Posted by tiro_uspsss View Post
    Are you sure it isnt your eyesight? Zanzabar is correct in everything he said. A Quick scan of the tech specs of each show the Pro and Extreme are EXACTLY the same except one is internal, the other is external through a crap interface
    Rig 1:
    ASUS P8Z77-V
    Intel i5 3570K @ 4.75GHz
    16GB of Team Xtreme DDR-2666 RAM (11-13-13-35-2T)
    Nvidia GTX 670 4GB SLI
    Rig 2:
    Asus Sabertooth 990FX
    AMD FX-8350 @ 5.6GHz
    16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
    AMD 6950 with 6970 bios flash
    Yamakasi Catleap 2B overclocked to 120Hz refresh rate
    Audio-GD FUN DAC unit w/ AD797BRZ opamps
    Sennheiser PC350 headset w/ hero mod
    I am Xtreme
    Jan 2006
    Australia! :)
    Quote Originally Posted by EniGmA1987 View Post
    I'm looking @ :
    ..WAIT! I just found the problem!
    use the drop downfield & switch the Pro to the USB3.0 model - then you will see updated spec page for the Thunderbolt model - & you will see that it does 1080P50 & 60, whereas the other two (Pro & USB3) don't!
    heatware / ebay
    Jun 2008
    Winter Springs, FL
    You're probably going to just need a Mac.
    If you want TB anytime soon, get Mac.
    Why yes, yes I do use Koolance..*Flame Wall Inbound*
    I am Xtreme
    Jan 2006
    Australia! :)
    Quote Originally Posted by The Jesus View Post
    never ever will I buy a mac... closest thing I have & ever will have is my hackintosh
    heatware / ebay
