Yea, I know that it's an unpredictable function between voltage and clock speed. (sigh...) The fact that it CAN potentially get quite hot (and the fact that the voltages CAN be quite high) is why I had asked about the premature death question. Couldn't put numbers to it before, but the cause for concern still remain the same.
I ended up finding a 4U rackmount that has 120 mm fans inside. I forget who makes the 80 mm fans that's in my 4U. It's a pity that the watercooling isn't the one that's sending the feedback signal to the PWM controller for the fans.
I can make the app use as many processors as I want. However, to answer your question, for this particular type/class of analysis, HTT is currently showing a 3-12% DECREASE in performance (vs. without HTT). I haven't tested it with CFD yet (either using the same program or using a different program). Also note that the HTT tests were performed on current generation Xeons.
I also just realized that if I get a rackmount, I might actually have to flip the air flow direction around so that it actually goes back-to-front. Hmmm....
Bun-Bun - are you volunteering to do the testing for me?
BeepBeep2 - No, a little bit smaller still.
re: faster waterflow - sort of. upto a certain point.
re: noise - be clearer next time (about what it is that you're talking about). To make generic statements means that it is subject to the test of universality.
re: $hit straight - considering that I've been able to highlight some blantant flaws in your points of argument...the rest is self explanatory.
re: rackmount - it was a tongue-in-cheek commentary on the absurdity of some of the comments/replies. Constantly beating on "it depends on voltage/speed/what processor you get" is about as useful as "no freakin' clue." So, while yes, the statement is true - how would presenting the null or void hypothesis be useful at all? In fact, I've already mentioned SEVERAL times that "yes, it depends on voltage and speed" (perhaps not as blantantly spelled out for you, but here it is, blantantly spelled out), but I've also already told you that if you have a bunch of people OCing to 4.5 GHz, you're going to end up with some kind of statistical distribution on both voltage, speed, AND temperature.
Considering that leeghoofd is able to say that 4.5 GHz (+/- 0.1 GHz) @ 1.3 V (+/- some value V) and running at 77.5 C (+/- 2.5 C) average just proves that. Granted, that's just his sample data point. I'm going to guess that he's not the only person that's ever OC'd to 4.5 GHz and so there's going to be more data and you can fully form the 3D statistical surface. (some higher voltage, some lower voltage, some faster, some slower, some hotter, some cooler). But it's going to be within some range on some kind of statistical distribution. (I hate stats. Grrr...)
You do realize that they make ATX compatible rackmounts right? And that the ATX spec only refers to the size of the motherboard, the mounting hole locations and stuff. For all practical intents and purposes of the discussion, I could have easily said "I'm going to mount it on ATX spec plywood". (I won't) but the point is that whether it's rackmount or tower - it doesn't matter. ATX spec does not govern what form the enclosure comes in. Therefore; the part where you said "use ATX specification part" has nothing to do with whether the people here are familiar with rackmounts or not. Here's a list of ATX compatible rackmount enclosures from Newegg (211 results):
http://www.newegg.com/Product/Produc...=1&PageSize=20
re: "pretty darn close"
Attachment 124874
(Not my work, NCAC model).
I'm trying to find the SAE paper or the AEI article comparing the physical crushing of a tube to the simulation and how close the simulation has gotten. (Not that you would actually care... - I mean...it only protects your LIFE in your car. Yes, I am assuming that you drive. Or been in one.)
