It starts off with two very simple questions (actually...one...really) and then people go off on all these stupid tangents about directional airflows and b--ching about counterproposals or that they would mention one component, and I'd mention why I couldn't (or more specifically) didn't want to go with that component that they mentioned.
Bun-Bun - the question is really simple. It's not that complicated. But at least I'm working with actual data, not just on gut feel.
They're not a threat.
(Who is "they"? Everyone that isn't an engineer here?)They would be if they could actually argue on a premise
(Which I am?) than mere "gut feel".
Can I go with an open kit? Yes. But by the same token, I could have gone with a custom waterblock too. *rolls eyes* Or direct die evaporative cooling too! (Way to say smart-ass things, does he not realize a "custom waterblock" would gain him measureably nothing over WB's on the market?) And clearly, if I'm making references to H80/H100, yes, the open kits are an alternative; yes, I don't think that I would be spending the time to actually do what
BeepBeep2 suggested in terms of getting the kit, cutting the tubing to size, leak testing it, and then running it.
(He doesn't know what I meant, I was talking about Swiftech/XSPC/EK kits)...
Some of the other points of argument from this thread is quite simply...just dumb. The whole "simulation vs. real world" part - yea. Dumb.
(Bun-Bun just proved you wrong...)
If the real world was so important, then why is it that pretty much EVERYBODY is moving to simulations?
(Because simulations are a GREAT tool to maximize efficiency of a single component, or course!)
Why WOULD we run simulations if guys like you think that I'm stuck in the stratosphere somewhere???
To me, that just reeks of people's ignorance (I reek of ignorance?) about what simulation engineers do (regardless of whether it's mechanics, fluids, or both. Or multiphysics.)
Its fine for you guys because you are able to physically pick up a part that's already been tooled, shot and shipped, with your hands, look at it and screw it in the case. (That isn't exactly what we do here. Maybe that is what average joe does, and when it works he is happy.)
But what do you do when tooling cost half-a-million dollars (actually, the end of line measurement system is a half-a-million dollars), and you DON'T have parts made yet because you haven't crossed the marker for a design freeze for your tooling guys to tool to? Are you able to tell me what the M and M' are??? I mean, I can ALWAYS make the problem more difficult for you guys. MUCH more difficult.
(Who cares in this situation where efficiency/design improvements would not be worth the cost/time?)
But the point of some of those "back-of-the-envelop" type of calculations is to be able to very quickly show why something likely will or won't work. So, if you can get the blade parameters of the fans in question (the parameters that I'll need can be found in just about any sort of turbomachinery handbook), I would then be able to model explicitly the hub and the entire fan performance curve (minus statistical deviations, electrical to mechanical transform inefficiencies; unless I'm fed the line information as well.) (...well, what about the noise curves? People also prefer lower hums than high pitched whines, you can't plot that data without the real-world)
As dumb as I am and as intelligent as the rest of this community is - how someone misses that point is beyond me.
(Nobody does...but then again we weren't even talking about that.)
This isn't a pissing match to see who's smarter.
(You are trying to make it that.)
I came here to ask because I figured that I would be able to get the best, most professional advice and so far, it's been greeted with mostly nothing but disdain for the original question.
(There was nothing wrong with the original question.)
Are your heads so far up your own arses that you can't see daylight anymore?
(No, yours must be.)
And one of the major differences is that I know what my limitations are and won't claim to know more than I do.
(Actually, you don't even know how the parts work in harmony and what weight each part carries in achieving the goal, you only care about a part by itself)
Heck, even if I've done the research, I won't necessarily claim that it's fully complete and accurate either because I haven't actually taken the painstaking task of actually modelling the entire computer in tremendous detail.
(This has nothing to do with modelling the computer. You can't predict the temperature of your CPU (which I said was a real-world variable) by simulation. You have to take into account the flow rate of the pump, efficiency of all the parts, thermal paste, thermal contact, there are too many things here for you to be able to calculate without the real-world. Also, I'm not talking about gut-feeling. I'm talking about taking measurements.)
Course, I reckon that most of you here probably don't care for that either (since obviously, we're not into facts here).
(We are into facts here. We're into very simple facts you can't even comprehend because you won't open your eyes.)
You want to talk about insulting -- try asking someone for help and all they can tell you is "you've seem to have made up your mind already, so good luck" or "what's the point of those calculations? That's not even accurate. You have to take into the account the hub..." (why haven't you mentioned the blade pitch and angle, and pretty much all of the other turbomachinery parameters and characteristics???)
(We haven't mentioned the blade pitch and angle, and the other turbomachinery parameters and characteristics because we are consumers. That doesn't mean we can't comprehend roughly what blade pitch, angle, etc is optimal because we've tested a plethora of products!)
That would be like if I were to ask you how I can make the engine of my car produce more torque, you'd be telling me that I need to increase the clamping force on the forge press by 2 tons. Or that I need to closely monitor the metal porosity or the carbon penetration. While yes, those would be all true, it completely fails and misses at answering the big picture question.
(...of course, we're not retarded.)
Is it direction of airflow important? Yes. But I'm surprised for such directionally happy people, no one's mentioned going to a 3U rackmount yet. I mean - come on. That would be a no brainer given the direction that this thread is going?
(We didn't mention a 3U rackmount because it is irrelevant to what you wanted?)
I remember that Asetek (I think is the name of the company) used to come out with some coolers and I think Koolance was another one. Now, I'm not in the OCing world. Never really have been. So I figured that maybe someone else would have mentioned some of the new stuff that they might have that are closed kits that will do better than the Corsair.
(Asetek makes the Corsair H50 and H70, CoolIT makes the H80 and H100. Forget Koolance, you don't know what you're talking about.)
And in my initial research, I also did come across Thermalright's Silver Arrow air cooled HSF, but they were testing I think on a quad core 2500K (OC'd to 4.8 GHz). So I would think that with two extra cores, that the thermal load would be even higher.
(Yes. That is a good air cooler to look at though.)
I didn't know that Noctua had a fan that fit Socket R. (Good to know though).
(I already told you that it is more commonly called Socket LGA 2011, or more specifically FCLGA 2011)
Now I'm really curious as to why
SnowyOwl went with a liquid cooling solution (while
Bun-Bun went with an air solution - which he's stated why).
(Because liquid cooling is much better. I'm not talking about the all-in-one solution.)
Why is it that whenever I ask an OCing question, it seems like all the d1ck$ pop out of the wood works? Seriously?
(They don't, you just come back with arrogance and spite, as if we can't add prices, for example)
It isn't about a who's smarter or not thing.
(You already said that.)
If I were really on the high horse, I wouldn't even need to ask you guys (cuz I'd be a know it all, already, wouldn't I?)
You kind of act like it!
It's no effing wonder why I never go into the whole OCing world. It is my experience from not only this forum, but a whole bunch others that HPCers seem to be more courtesy and professional than OCers and yet I can never understand why that is.
We don't go into an HPC forum and talk like we know everything in response to suggestions.
After interacting with you guys in the past day or two, I'm REALLY thinking of going with the $22k, quad-blade, eight-socket system instead because I know that if I EVER have a question, it will be met with professionalism and courtesy rather than by a bunch of discordant and immature pr1ck$. Grow up.
(Yeah, okay.)
You wanna talk about real world/reality - talk to me when your EAU volume is 140,000 units a year, where the lead time for tooling is a MINIMUM 12 weeks from China, a change (to said tooling) is 4 grand, the end-of-line inspection system is half a million, a gauge change is half-a-million, and you have NO physical parts to work off of/test but the VP of Engineering AND your customer is asking you to answer the question: "How will it perform?" Let's see how well you guys would fair on with that.
Go step outside and talk to some normal people. The kind that make up majority.
