This is my first WaterCooling MOD. I wanted to do something special, something that was at least the height of my hardwares. There are several reasons, such as squeezing more power with my current hardware Benchs, Games and of course, improve temperatures. So we started with this exciting adventure!
COMPONENTS OF LIQUID COOLING
*SilverStone TJ 11
*Corsair AX1200
*EK Ram Dominator - Acetal / Nickel
*Aquacomputer Cuplex Kryos HF
*EK Waterblocks EK-FB RE3 - Acetal / Nickel
*Bitspower Black Freezer VG-NGTX 580 x2
*EK Water Blocks EK-D5 DUAL TOP
*Laing D5-Vario 12v x2
*Lamptron Touch
*HW BlackIce SR1 240
*HW BlackIce SR1 480
*Nidecs GT 1850 rpm x6
*SilverStone FF101 DUST FILTERS x6
*EK Waterblocks EK-Multioption RES X2 - 250 Advanced
*Mayhems Dye Red
*Tygon 19/13
*Prolimatech PK-1 x2
*Adaptor Scythe Bay Rafter 3.5 a 5.25 HDD
*Velcro- Danger Den D5 x7
*Carbon Vinyl 3M
*AlphaCool HF 5-Way Colector G1/4 Deep Black x2
*Adaptor 1/4 a IG G1/4 Rotable Bitspower BM x2
*Adaptor Multilink Bitspower BM x4
*Bitspower Compresión Fittings 19/13mm BM x15
*Compression Fittings 45º Bitspower BM x10
*Adaptor 90º Bitspower BM x4
*Adaptor Q Bitspower BM x4
*Plugs Bitspower G1/4 BM x10
*Phobya Radiator Stand 4x120mm
*Phobya Radiator Stand 2x120mm
*BitFenix 24-pin ATX Cable Extension 30cm
*BitFenix 8-pin EPS 12v Cable Extension x2
*BitFenix 6-pin VGA PCI Express Cable Extension x2
*Bitfenix 8-pin VGA PCI Express Cable Extension x2
*Bitfenix Adaptor 3-pin 60cm
*BitFenix Adaptor 3-pin 90cm x6
*BitFenix Adaptor Molex x4 Sata 20cm
*Nzxt Sata 4 in 1 20cm
*P-Clip 16mm
*P-Clip 19mm
*P-Clip 3mm
*P-Clip 6mm
*P-Clip 9mm
POSSIBLE SKETCH
