ah good information man. thanks
When LN2 tests do you plug in the GPU Reactor (It is very important.)
And...In my&Gyrock case, less than -60 degrees, will freez after the start of the bench.
Thank you so much my friend![]()
2010 MSI MOA Grand Final #4
2011 MSI MOA APAC #2
Hoping to pick one of theses up next week
CASE,Corsair Graphite 600T LE White Waterchilled
M/B,Asus Rampage X79 CPU,3930K
RAM G.Skill Ripsaw 17600CL7-2GBXHD 2133 6-10-6-22-32
GPU Asus HD 7970 Matrix Platinum SSD2xOCZ Vertex 4 128GB HHD,Western Digital VelociRaptor 600GB 10000RPM PSU,Antec HCP 1000w 80+ Platinum
Do you try adding +100 AUX?
Here is my settings for 1650/1900 (CPU is at 5ghz sorry for blocking it)
Pot at -95c GT1 / -85c GT2 GT3 / -80c GT4 / -75c Physics / -78c Combined
If pot is colder then -78c during physics it freezes the screen but combined needs a little bit more cold to pass
getting my 7970L later.. hope for a good clocker!![]()
great works bro!!!!![]()
I tested mine card with cold water (idle 10c and max 21c core)
On air my card was maxed 1.2vcore 1200MHz and more vcore didnt help me at all.
On water it turned out 1.3vcore was okey and max clocks were 1350Mhz. (Tested only with 3dmarks)
Hope that info helped u a bit.
Every card wont scare even that much i think but this card could do pretty well with ln2![]()
X58: R3E & XPOWER | 980X | GTX580 | 3x2gb MGH-e | Dimastech | AX1200
s775: RE | E8600 | GTX285 | 4x1gb D9GTR | P&C 610W
SB: 2600k | Asus P8P67 & Gigabyte UD4 | GTX 460 1gb | 550W Cougar
@emertX
You must not send a message.
The following errors occurred with your submission
emertX has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
