Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: Repairing of 3 Single-stages: Vapo LS, Mach 1 and LD unit . WORKLOG
    -100c Club Member
    Mar 2005
    Poland
    Hello
    Currently I work over repairing 3 single-stages units:
    -vapochill LS
    -Prommie mach 1
    -LD unit.
    Each have been incomplete and/or damaged .
    Units were not good packed for shipping .
    Vapo LS (the strongest damage ), LD SS and Mach 1.
    Mach 1 has been without suction line.
    I've started with Prommie
    I've removed stock electric.
    More pictures soon .
    Regards
    Peter
    Apr 2005
    Closer than you think.
    Great to see you back at it!
    Wow, some 'wrecks' to work with. Did you get any panels too, or are they trashed as well?
    I'm sure they'll get the usual attention they deserve Anything special planned, or just bringing them back to life?
    Gray
    [SIGPIC][/SIGPIC]
    Administrator
    Nov 2007
    Stockton, CA
    Good grief, such a mess to clean up
    Reminds of the unit FEDEX dropped off of a two story building that I had going to a customer.
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Those photos are all too familiar to me. I don't envy you at all
    -100c Club Member
    Mar 2005
    Poland
    I'm not back, I'm in all the time .
    Owner of those units have panels at home, they weren't shipped to me because they can be damaged during shipping .
    About special - I don't know if painting of cases is special ?
    Jan 2005
    Germany
    oily desaster
    hope you'll get them working well.
    how much load are you tuning the units? will you boost the condensers to get rid of more load?
    Admin
    Mar 2003
    North Texas
    Looks like they all came from the same place. What's the story behind that?
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    -100c Club Member
    Mar 2005
    Poland
    Quote Originally Posted by Patrickclouds View Post
    Yes Currently I'm finishing Mach1 with much bigger condenser (owner supply me also that condenser). But one fan on condenser is still too little, those Panaflo fans from stock Prommie 1 are weak So tomorrow tests with push-pull (push = Delta 120x38mm , pull= panaflo from mach1).
    About load I start from 315W, if will be too much - I use lower loads.
    Owner of those units bought them cheap or even get them for free - I don't know really. Vapo LS was moded already by another phase-changer in DK. First plan was to take only NL11F compressors from them for SS CPU+GPU project but finaly I make those project on 2 rotaries and repair those small units .
    -100c Club Member
    Mar 2005
    Poland
    Prommie Mach 1 in progress :
    Fresh oil.
    Case will be black now .
    New suction line by me - braided flex + 42mm steeper.
    And some first run in cold workshop :
    Finaly it'll run much warmer .
    Administrator
    Nov 2007
    Stockton, CA
    Nice job Peter !
    Sep 2008
    Belguim
    nice work Piotres
    proud to be from Belguim ^^
    Lightpainting and hardware are my life!
    -100c Club Member
    Mar 2005
    Poland
    LD unit before mod.
    New black paint . Not powdercoat, just cheap homemade wet acrylic paint.
    Leak testing with nitrogen in water .
    Holddown must have been moded because I had only versions for 42/54mm evaps, and that one is 38mm.
    Also MUCH bigger condenser. New drier, added shrader valve on discharge side.
    to sum up .
    BEFORE:
    AFTER:
    Admin
    Mar 2003
    North Texas
    Wow!!
    UNDER THE ICE .com
    is the remedy
    Administrator
    Nov 2007
    Stockton, CA
    Quote Originally Posted by runmc View Post
    Wow!!
    Agreed !!
    -100c Club Member
    Mar 2005
    Poland
    Yes, it's Your condenser . On front now is DELTA 120mm, I don't know exactly how many CFM but for sure way over 100CFM . Stock Prommie's fans are very weak compared to it.
    I am Xtreme
    Aug 2008
    I know those condensers too hahahha
    the before and after pics are the same..but i saw the bad pics and the final pics are just pretty.
  18. #18
    Jul 2003
    Rio de Janeiro - Brazil
    Thats is a very nice condenser....
    How much heat can it dissipate ?
    Q9550 EO @ 4.1
    Asus P5Q Deluxe
    4 Gb DDR2 Gskill
    2xVelociraptors 300 gb Raid 0
    Sapphire Vapor 4870 1Gb
    PCP&C 750w silencer psu
  19. #19
    -100c Club Member
    Mar 2005
    Poland
    Dimas should know that
  20. #20
    Dec 2004
    Austria
    wooow, really great work. I am also looking for someone who can repair my damaged SS. maybe we can make a deal ?
    1st: i7 2600K@4,6Ghz@1,28 Vcore || Asus MIVE Rev.3 || Bios 3208 || 2 x 4096 MB Corsair Vengeance || Asus GTX 580 CU II || WC with Koolance-370 || EK-VGA Supreme HF || Mora3 Pro
    2nd: i7 2600K@4,6Ghz@1,32 Vcore || Asus MIVE-Gene Z68 || EVGA GTX 280 || 2 x 4096 MB ADATA XPG G Series v2.0 || WC with - EK-Supreme HF Full Nickel || VGA HK || Mora2 Pro
    5,0 Ghz LinX_Stable_Club
  21. #21
    -100c Club Member
    Mar 2005
    Poland
    Why not ? You have PM .
  22. #22
    -100c Club Member
    Dec 2004
    Europe
    It is not LD unit, it is just LD case, it was build by someone ealse.
    Kind Regards
    My Work: LittleDevil's SS Cases, LittleDevil's SS Worklog, LD CPU-R1 Dice/LNē Pots, LD GFX-R1 Dice/LNē Pots,
    LittleDevil LD PC-V10, LittleDevil's K-Type Temp Display, |EMAIL: ldphasechange@gmail.com
    LD PC-V8 Watercooling Cases:
    LINK
    LD PC-V8 ATX/HPTX Watercoolig PC case with 10 expansion slots: LINK NEW!
    www.ldcooling.com
    Find US on Facebook
  23. #23
    -100c Club Member
    Mar 2005
    Poland
    Now Vapochill LS:
    Case has been heavy damaged, so I decide to remove it ...
    +remove whole stock electric.
    and scrap it ..
    That's amount of oil which I've poured from compressor :-O - approx 20 ml.
    And that's suggusted amount of new oil.
    Now that will be just benching unit on baseplate .
    First time I soft-solder captube to accumulator - and I've loved that work .
    Pressure testing of whole unit together .
    Regards
    Peter
  24. #24
    -100c Club Member
    Mar 2005
    Poland
    Quote Originally Posted by LittleDevil View Post
    Kind Regards
    Really ?
    Those unit from pictures in first post here: http://www.xtremesystems.org/forums/...log&highlight= looks 100% same - even style of bending of pipe after condenser, drier and style of painting near condenser is same.
    Owner of those moded unit wrote me that's 110% sure unit made by You ...
  25. #25
    -100c Club Member
    Mar 2005
    Poland
    "vapochill LS" has been finished and loadtested :
    Final unloaded temperature.
    Final 315W load temperature.
    We decided to change evap in "unit with LD case"- old wasn't flat .
    Plus suction line will be much longer now. Second suction line for another unit (CPU+GPU ).
