Results 1 to 9 of 9
Thread: Does anyone know what IC's have these memorys?
    Sep 2008
    ROMANIA
    If someone know what IC's have these memory can please tell me
    I want to buy a kit and i don't know which are better.
    OCZ Blade ST 4GB (2x2GB) DDR3 1600MHz OCZ3BST1600LV4GK
    CL 7-8-8-26 (CAS-TRCD-TRP-TRAS)
    1.65v
    Qualifed on Intel P55 Chipsets and Core i3, i5, i7 CPUs
    Qualified on AMD 7 Series and 8 Series Chipsets, X4/X6 CPUs
    Product page: http://www.ocztechnology.com/ocz-ddr...l-channel.html
    OCZ Reaper 4GB (2x2GB) DDR3 1600MHz OCZ3RPR1600C8LV4GK
    CL 8-8-8-24 (CAS-TRCD-TRP-TRAS)
    1.65v
    Qualified on Intel P55 Chipsets and Core i3, i5, i7 CPUs
    They are BBSE?
    Also did anyone tested
    Tanscend aXeRAM 4GB (2x2GB) 2400 MHz TX2400KLU-4GK
    CL 10-12-11-28, 1.65v
    http://www.transcend-info.com/Products/MEMList.asp?srhMemWay=STD&L0No=Transcend&axn=goSea rch&LangNo=0&L4No=110
    Can they go above 2400?
    i5 2500K@ 4.5Ghz
    Asrock P67 PRO3
    P55 PRO & i5 750
    http://valid.canardpc.com/show_oc.php?id=966385
    239 BCKL validation on cold air
    http://valid.canardpc.com/show_oc.php?id=966536
    Almost 5hgz , air.
    Apr 2011
    Deadmonton, Alberta
    The OCZ Blade ST kit sounds like it could have D9 ic's. I have an older mushkin blackline kit with similar timings and it is D9.
    Intel 2500K 4.7Ghz @ 1.35v
    MSI Z77A-G45
    G.Skill Ripjaws X 2133MHz 8GB 9-11-10-24 1T
    Gigabyte HD7970 WF3 OC Crossfire
    Crucial M4 64gb Raid-0
    Corsair Force 3 240GB
    Silverstone ST1000-G
    Coolermaster HAF932
    Jan 2005
    Home
    My old Reapers were Samsung HCF0, as were my Platinums.
    775 was the validation back then.
    REX4F - X79A-Sabertooth
    Noctua NH-D14 Pull-Pull NoiseBlocker PK3
    X3930 @4.5 - 1,325V
    X3860 @4.5 - 1,28V
    Geil Ultra+ 6x4 7-8-7-24@1814 1,65V Elpida???
    Gskill RJ-X 4x8 9-11-11 @2200 1,65V Sammy
    580 SLI
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    I can only speculate but here we go: First one is probably some kind of PSC, might be Micron as someone said too, second most likely Micron and the third kit is Hynix BFR. Honestly none of these kits is really great, can't you get something else?
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
    Sep 2008
    ROMANIA
    Well these kits are new stuff in a store in my country and i thought they might be some "good stuff" some good memory which didn't sold in other countrys. The 2400kit i knew what chips are but can they go much above 2400?
    In Romania is a little harder to find good memory in stores.
    Anyway i think i will buy some Avexir 2000CL9 BBSE second hand kit which can do at least 2200CL 9-9 1.65v and some guy tested on SB-E and says it can do 2400 CL11-11-... 1.70V quad channel.
    Thank you all for answers.
    i5 2500K@ 4.5Ghz
    Asrock P67 PRO3
    P55 PRO & i5 750
    Almost 5hgz , air.
    May 2007
    Munich, Germany
    I don't like any of these kits.
    The Transcend might be able to do 1250-1300MHz at 11-12-12, but it depends on the IMC a lot, and 1200MHz 10-12-11 is a rather bad bin. In your case I'd definitely go for the BBSE kit, they scream on SB, you should be able to to 1100MHz 8-9-8 or 7-9-7 @ ~1.65V.
    Xtreme 3D Team
    Jan 2009
    Ohio
    The Avexir BBSE will do the best.
    Smile
    I am Xtreme
    Aug 2008
    don't buy the ocz rams....
    sorry ocz reps :P
    Xtreme 3D Team
    Jan 2009
    Ohio
    Quote Originally Posted by Hondacity View Post
    sorry ocz reps :P
    How about
    "don't buy OCZ anything..."
    sorry OCZ reps quality control leaves a little to be desired
    Smile
