Hi there.
Im about to build my new loop and i need some advice.
The hard ill use is: asus maximus 4 gene-z/gen3 with a 2500k and a gtx580
The 2500k will be under a HK 3.0 and the gtx580 will be under a Swiftech MCW82 with the heatsink.
The rads ill be using are magicool slim 2x120 (two of those) with 4 sflex @ 800 rpm and the pumps are two d5 with the ek serial top. Res is a ek multiport. BP compressions, silver coils and thats about it.
Also some aquacomputer sensors (temp and flow) with an aquaro (old one).
Which of this setups will have better noise/performance ratio.
All serial
1) Res -> Pumps -> Rad 1 -> Rad2 -> Cpu -> Gpu -> Res
2) Res -> Pumps -> Cpu -> Gpu -> Rad 1 -> Rad2 -> Res
Parallel (Y = Thisfitting)
3) Res -> Pumps Y -> Cpu -> Rad 1 -> Y Res
-------------------------> Gpu -> Rad 2 ->
4) Res -> Pumps Y -> Rad 1 -> Cpu -> Y Res
-------------------------> Rad 2 -> Gpu ->
5) Res -> Pumps Y -> Rad 1 -> Y Cpu -> Gpu -> Res
6) Res -> Pumps -> Cpu -> Gpu Y -> Rad 1 -> Y -> Res
--------------------------------------------> Rad 2 ->
I have thos Y fittings and wanted to use them. All this is going to be inside a Lian Li v351 so less tubbing = better.
Also using parallel loops i could use the pumps with lower setting (both on two instead of 3 for example) = quiet system.
Im going to oc the 2500k but not much. Temps are not ment to be ultra low, my main priority is to have a ultra quiet systems with good temps.
Which loop would be better?
Thanks all
