+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 33 of 33
Thread: DIY first time singlel stage
  1. #26
    Xtreme Member dejanbinladen's Avatar
    Sep 2008
    Croatia
    0
    its 0,7mm
    i used gary loyd calculation and it should be ok ?!?!?!?!
  2. #27
    -150c Club Member n00b 0f l337's Avatar
    May 2005
    NJ
    11
    The Gary Loyd hasn't really been applicable in half a decade
    Quote Originally Posted by Movieman
    Thanks for the compliment but unlike that bartender you mentioned I'm not sleeping with you no matter what you say!
  3. #28
    Sep 2008
    Croatia
    0
    dont do this to me not now when is almost finished :S
    pitores says
    "IMO use 1,5m, won't be too short.
    cutting captube needs removing gas and evacuation all the time ..."
  4. #29
    Admin runmc's Avatar
    Mar 2003
    North Texas
    10
    If you use r404 or r507 you will need POE oil. POE oil is very sensitive to moisture. It will obsorb moisture out of the air easily. I see you running the compressor with valves open. You are pulling moisture into the unit. Maybe not much, but it doesn't take much to contaminate the system. Also you are pulling mositure into the filter/drier. Not good.
    You also need to seal the space between the condenser shroud and the condenser.
    Jesus is the remedy
  5. #30
    Sep 2008
    Croatia
    0
    ok thx runmc
    i cant translate very good this "You also need to seal the space between the condenser shroud and the condenser. "
    and what do you think of the capilary lenght ?!?!?!?
  6. #31
    Mar 2003
    North Texas
    10
    I see in your video there is an open space between the fan schroud and the condenser. You want all the air to be pulled through the condenser. A lot of air will get pulled through the open space and not the condenser.
    I am using 7' 5" of .031 right on a cooler I am building. You need to tell us the O.D. of the captube you have so we can give you a approximate length.
    Jesus is the remedy
  7. #32
    Sep 2008
    Croatia
    0
    prototype is done, not -50 but its good for first DIY
    freon is R22 cause guy said that R507 would be to much pressure for teh compressor, he fine tuned, and its about -35 on manometer without load.
    soon i will be building somethiong better then this but this is victory for me also and would like to thank everyone who helped me wtih this. thanks guys
    dejan
  8. #33
    Sep 2008
    Croatia
    0
    here are some preliminary tests without load, temp on evap, consumption in watts and amp
+ Reply to Thread
