Virtu Universal MVP Enable
http://www.xfastest.com/thread-72998-1-1.html
Nice board. I love the new ASRock boards and my P67 Extreme4 Gen3 is really good. The only crap is the position of the extra molex for CF/SLI setup and I see they didn't change it
I guess I've been hiding under a rock for a while, but from what I saw there, the new Lucid Virtu MVP technology helps out quite a bit, correct? If so that is quite spectacular
Yes if this work in games too(which should work) than it's avesome
From Asrock site:
Virtu Universal MVP - Uncompromised Game Response Performance
1. HyperFormance™ :
A new technology which combines integrated and discrete graphics for uncompromised performance and improves gaming frame rates 30-70%.
It’s also supported with both ATI™ and NVIDIAŽ graphics cards.
2. Virtual Vsync :
A technology designed to solve the ever lasting debate between quality and performance. Bring GPU performance from 60 FPS Vsync limit back to its maximum while keeping Vsync image quality and no tearing.
i5 2500K@ 4.5Ghz
Asrock P67 PRO3
P55 PRO & i5 750
http://valid.canardpc.com/show_oc.php?id=966385
239 BCKL validation on cold air
http://valid.canardpc.com/show_oc.php?id=966536
Almost 5hgz , air.
NDA lifted already in Taiwan :p
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
I warned you
virtu mvp IS GONNA SURPRISE
this is VERY interesting,
Q9650@4288 10.6sec 1m superpi water ||Asus P5Q Deluxe||4Gb Ballistix Tracer red||4870X2||Corsair1Kw
How about microstuttering? Isn't this MVP thing using AFR? If you couple that with asymmetric resources like a slow and a fast card you are bound to run into choppiness.
How much driver dependancy is there in Mvp? will it need profiles to work?
Also, I don't spot any ocing in this test either...
Are there any OC results anywhere on ivy ?????
i7 6700K @4.8 ghz
XSPC RayStorm (very nice block)
Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
XFX-7970 with Swiftech Komodo nickel block
Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
Crossfire 30" decent monitor for IPS too bad SED tech died
Docsis2.0 Docsis3.0
-- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
http://www.xtremesystems.org/forums/...k-today./page4
Virtu Universal MVP Enable + Overclocking = enhanced rendering towards BSOD?
i7-2600k L041C108 4.8ghz 1.32v PLL off Venomous-X Push/Pull http://www.xtremesystems.org/forums/...postcount=1063
Asus P8P67 Vanilla
Samsung 30nm MV-3V4G3D/US 2x4GB @ 9-10-10-28 1T DDR3 2133 1.6v http://www.techpowerup.com/forums/sh...d.php?t=159320
Diamond HD 7970
WD 600GB Velociraptor
Corsair TX750W
CM 690 II Advanced
Q822A549 E8500 @ 4.5ghz air TRUE @ http://www.xtremesystems.org/forums/...d.php?t=203762
G.Skill F3-12800CL6D-4GBXH @ 7-10-8-27 1T DDR3 2133 1.6v http://www.xtremesystems.org/forums/...d.php?t=266839
wow, loving the MVP technology. Atleast then, the inbuilt gpu is less of a waste for us using dedicated cards. Would it make the CPU run hotter?
Hating the molex connector though. What is it for?
Edit: My bad. Asus has virtu MVP also.
It also seem it works with z68 cards, but not as well? http://forums.guru3d.com/showthread.php?p=4266014
those graph look amazing
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
MVP... special to very certain boards only? This seems like a very interesting feature as it's not only a small but a quite noticable boost. I'm sure there has to be a hook somewhere (microstuttering?) besides price.
Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
If all people would share opinions in an objective manner, the world would be a friendlier place
Some time ago I read in an article about this feature that they leave out rendering steps that would supposedly not degrade image quality. I'm highly sceptical about this thing. In fact, I think it's nonsense. To make yourself dependent on profiles with a single GPU is not wise.
I wonder how MVP would work with more than one dedicated card. Say if you where normally running SLI or something. Also i wonder what game support will be like. I remember LUCID promised massive things a while back as to revolutionizing the multi GPU market but the game support was pretty bad. I wonder if this will be any different.
CPU: Intel Core i7 3930K @ 4.5GHz
Mobo: Asus Rampage IV Extreme
RAM: 32GB (8x4GB) Patriot Viper EX @ 1866mhz
GPU: EVGA GTX Titan (1087Boost/6700Mem)
Physx: Evga GTX 560 2GB
Sound: Creative XFI Titanium
Case: Modded 700D
PSU: Corsair 1200AX (Fully Sleeved)
Storage: 2x120GB OCZ Vertex 3's in RAID 0 + WD 600GB V-Raptor + Seagate 1TB
Cooling: XSPC Raystorm, 2x MCP 655's, FrozenQ Warp Drive, EX360+MCR240+EX120 Rad's
what was the discrete graphic card used?
560ti
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
What's the price difference for a motherboard with MVP? Unless it's a freebie, it seems to me that you'd be better off spending the extra money on a better graphics card.
Any SLI is a potential pain. I'd thoroughly support letting my operating system only ramp up the GPU part of the APU in the desktop environment. That would let my video card stay idle. But I think I'd prefer it ignored the APU entirely for gaming. I suppose I'll have to wait and see how well it works in the reviews.
Virtu MVP does not work with multiple GPUs.
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
[XC] gomeler - Public note: If you PM me to tell me that I am disrespectful at least have space in your PM box so I can tell you I don't care.
[XC] gomeler - I come to the news section to ban people, not read complaints.
I heart gomeler!
