Page 7 of 7 FirstFirst ... 4567
Results 151 to 171 of 171
Thread: Team Xtreme LV 2400 9-11-11-28
  1. #151
    XIP
    Nov 2004
    NYC
    Team 3000 C11 seems to exist only in their lab. Pretty sure binning cfr or mfr to do 3000 @ 1.65V won't be easy.
  2. #152
    Xtreme Memory Hoarder
    Mar 2010
    here let me fix it for you
    Quote Originally Posted by Dumo View Post
    Team 3000 C11 seems to exist only in their lab. Pretty sure binning cfr or mfr or any ic to do 3000 @ 1.65V won't be easy.
    How many people have even completed a 3000+ 32M run? I know you have Dumo, but I can not really think of any other screens that come to mind and there is a reason for that, it has hard to find memory that is capable as well as an IMC capable cpu.
    I agree completely though, hopefully with Haswell 3000+ will be the norm with good Hynix/Samsung but I guess only time will tell.
    Quote Originally Posted by Hondacity View Post
    gskillllin it!
  3. #153
    XIP
    Nov 2004
    NYC
    Thanks L0ud
    The most important is to have fun with any ram kit, it can be 6m:16:450s or 3056 32m
    2933
    Uploaded with ImageShack.us
    2950, higher probly gotta go 2T
  4. #154
    Mar 2010
    Team 2666 c11 MFR @ 2800 MFR Profile via Asrock Z77 OC Formula 1.7v
    gskillllin it!
  5. #155
    Nov 2005
    The Netherlands
    1.7 is quite a lot for 1400c12 given 1333c11 as spec.
    Can they run 1400c11?
  6. #156
    Mar 2010
    did not test Sam, I will play with them tomorrow some more, time to go to sleep lol
    gskillllin it!
  7. #157
    PI in the face
    Nov 2008
    Quote Originally Posted by TaPaKaH View Post
    1.65 to 1.70 not a lot more is it :P just teasing
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
  8. #158
    Jul 2010
    Berlin, germany
    Seeing that the 2400c9 obviously become harder to get in Europe, and me getting out of mem testing, I think it might be a good idea to share some results and experiences I had with these, I had a couple of kits and even the fact, that quality varies a lot from kit to kit, doesn?t change fact that I like these. To make it short, here are some results of the four kits I still own. On Kit 3 and four, I have only a few results as these came the day at which I retired my sold IB system
    Kit 1
    2933 Cl11-13-13-35 1T 32M@~1,77v, voltage not optimized
    2800 Cl10-12-12-28 1T 32M@~1,65v
    3022 Cl11-13-13-35 1T 1M@*1,78v
    Kit 2
    2933 Cl11-13-13-35 1T 32M@*1,79v
    2800 Cl10-12-12-28 1T 32M@*1,68v
    Kit 3
    2666 Cl10-12-12-28 1T 32M@*1,58V
    Kit 4
    2800 Cl10-12-12-28 1T 32M@~1,7v
    My personal summary on these is, you can fail hard on these, my first kit was doa and I know several Kits that not only fail 2800 trcd12 and cas 10, but also start struggling at 2666 already, but compared to the lots of other Samsung Kits I had, I was lucky enough to find performance above 2666 which apart from these only my best 2666c10 tridentX kit provided, of which I had several that did not do as good as the worst of my 2400 c9 kits listed here. negative aspect on these is, as mentioned, that quality varies and you need luck or time to bin if you want first class Samsung - maybe these are no 2666c10 CDPT, but they also were sold at half price
  9. #159
    May 2008
    Decatur, GA
    I just don't get these sticks, or the C11 2400 kit. They simply will not run stable on my X79 setups at their rated timings/voltage, but there's nothing obvious like them failing memtest or anything.
    [EDIT] I just found this screenshot, it was a 1M run with these sticks@1400MHz C11 during my short-lived MSI MPower adventure.
    i7 4930K
    32GB Corsair Vengeance Pro DDR3-2400C10
    Asus Rampage IV Black Edition
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  10. #160
  11. #161
    3D Team Captain Don_Dan's Avatar
    May 2007
    Munich, Germany
    Thanks for posting your tests, very thorough.
    Quote Originally Posted by chew* View Post
    You can never have enough D9's.
  12. #162
    Champion
    May 2013
    Hong Kong
    MFR Testing ?
  13. #163
    Feb 2007
    TaPaKaH
    samsung or hynix?
  14. #164
    Nov 2005
    The Netherlands
    2666C10 are Samsung D (dual-sided)
  15. #165
    Aug 2008
    Atlanta
    Tested three 2666C10 sets on Haswell today, MHz/volt is decent but no ability to run 1400 tRCD 12 makes these a reject...
    set #1:
    set #2:
    set #3:
    Thanks for those Samsung D binning settings/results... I've been needing some help in assessing the quality of my various "D" kits.
    Ryzen 9 on the test bench... Sometimes older generation/tech as well.
  16. #166
    Mar 2006
    Sydney , Australia
    I have four sticks of 2400c9 to try on Haswell, hopefully they go OK. What tests do you guys use? Pi 32mb?
    Bencher/Gamer(1) 4930K - Asus R4E - 2x R9 290x - G.skill Pi 2200c7 or Team 2400LV 4x4GB - EK Supreme HF - SR1-420 - Qnix 2560x1440
    Netbox AMD 5600K - Gigabyte mitx - Aten DVI/USB/120Hz KVM
    PB 1xTitan=16453(3D11), 1xGTX680=13343(3D11), 1x GTX580=8733(3D11)38000(3D06) 1x7970=12059(3D11)40000(vantage)395k(AM3) Folding for team 24
    AUSTRALIAN DRAG RACING http://www.youtube.com/watch?v=OFsbfEIy3Yw
  17. #167
    Jul 2010
    Berlin, germany
    Memtest86 Dos and SPi32M for memory - for 24/7 settings you might use Prime for overall stability incl. CPU, IMC and Memory at different settings, Blend for example tests the Mems, not all that passes 32M is 100% stable for daily use
  18. #168
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Nicely Done Sam , thank you for sharing your findings. I have 2 sets of Cas9 2400 , one set is great the other one not so good. The best one can do 2800+ 10-12-12-31 and 2666+ 9-12-12-24.
  19. #169
    May 2008
    Decatur, GA
    Playing around with my crappy Team LV 2400C9 on Haswell. I forgot to set CR to 1 and can possibly lower voltage, but I was just trying to make sure it passed Super Pi 32M.
    Was able to run CR1 and tighten secondaries, but still needed 1.95V.
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
  20. #170
    Technician
    Jun 2002
    Merseyside, UK
    Saw a few results for the Xtreem 2600 C10 kits here so rather than start a new thread ill put mine in here.
    Tightest timings I can get into windows at gives really good AIDA bandwidth. Not sure I can stabilise it though, probably have to run TRP 12. This will do 8m SPi, rounds out in 16m or 32m though.
    1.05 vccsa, 1.15vccio, 1.6vdimm.
  21. #171
    Technician
    Jun 2002
    Merseyside, UK
    Didn't take much more to get 32m stable
