Probably he want to post this 4x4 2666C10......Euro450 !!:
http://www.caseking.de/shop/catalog/...it::20729.html
Need a Gigabyte latest BIOS?
Z370 AORUS Gaming 7,
GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
Evga GTS 450 SC, Gigabyte Superb 720W
XSPC RayStorm D5 EX240 (Liquid Ultra)
NZXT Phantom 630 Ultra Tower
Win 7 SP1 x64;Win 10 x64
Then you buy from your local dealer,it's very good price....
Does anyone know if there is any reviews for the C10 2666mhz mems, tried but haven?t found anything. The only thing i?m concerned about if i buy this top mems , it would be crap if my imc sucks. That?s why i?m thinking on C9 2400mhz to.
[SIGPIC]http://techsweden.org[/SIGPIC]
Gigabyte Z87X-OC, Haswell 4770K, 8GB Team Group 2666mhz, Asus HD7970
That second kit doesn't need nearly as much voltage as the first for the same clocks...nice! Have you tried higher clocks than 2666 with either kit?
In memory of Gracie, my sweet, sweet wife and mother of my children. Darling, we will miss you dearly. May you rest in peace (born to this world on March 30, 1976; went to her Heavenly Father on Good Friday, April 22, 2011).
http://animoto.com/play/E0wFhd6tN0nA...ent=challenger
Heat
I haven't, since I'm not fully sure if my platform can produce reliable results above 1333MHz.
Mine must indeed be from caseking as I bought them from a shop that is caseking's local B2B-reseller.
I'm selling the first kit if you want them
Wow, all 2400 C9 are NOT created equal. I'd say the Team are the strongest kit with those specs, followed by the G.Skill. The Corsair Vengeance are the weakest.
i7 4930K
32GB Corsair Vengeance Pro DDR3-2400C10
Asus Rampage IV Black Edition
2x GeForce GTX 780
Corsair AX1200
Cooler Master HAF-X
Dell U3011
I would buy the second Kit - 2600 CL10 with 1.53 looks nice.
I had the tridentx, the team and the platinum, team vary on quality very much, I also know results from other people who confirm that, the tridentx seem to be solid. Best 2400c9 I had were the Platinums imho, 2666 c10 at full slots 1,58v was quite good I think. Unfortunatley, my board is not very fond of corsair, but asus+corsair is bad story anyway, at least on cheaper board like my gene
Or maybe your clocking skills suck,stop blaming maximus v gene,it is a very good memory clocker,reached 2800 9-12-12 with corsair platinums 2666c10.
If you lack skills that doesn't mean that it's the boards fault
Anyone noticed that the second kit has an XMP-3200 profile ? Is that a fault or what ?
First kit you mean? Probably a mistake. I can't imagine 3200 9-11-11 with just 1.65V. If it does that however i will get me a kit.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
Just because you like to put 1,9v+ on mems, what every idiot can, this doesn?t mean this boards a good memclocker - I can easily run 2666 9-12-12 at 1,73v with 4x4GB, but the with 2666c11 and the 2400c9 dominators I have ebormous difference at 2800 from memtest to win 32M - a difference I haven?t with GSkill or Kingston - and btw, brute force has nothing to do with skills, in case you already forgot first part of my statement
TaPaKaH, I bet it isn't every day that you're told that perhaps the reason for your hitting a wall is that your ram OC skills suck.Or maybe your clocking skills suck,stop blaming maximus v gene,it is a very good memory clocker,reached 2800 9-12-12 with corsair platinums 2666c10.
Heat
2666C11 is hynix chips,2400cas9 is samsung,you mix apples with pears. Every chip has it's particularities,you obviously don't know that and blame the motherboard?Seriously?
Please find a rope and hang yourself,or at least stop posting around your aberations
my reply was for websmile not for tapakah
I guess everyone across the pond has gotten up in a good mood and filled up on their favorite cup of java, 'cause you guys are fired up today.
Heat
Clocking memory has so many factors involved,like IMC then memory Itself then the mobo...different imc clock memory different not necesarly related to mobo.rog series and asrock Oc formula do not limit your memory clocking,you can't blame the mobo first....it' just retarded...
CPU-Z frequently misreads XMP profiles, I'm not sure if the XMP is actually DDR3-3200 (never bother testing such stuff).
I would have to agree with websmile here, if you can do 1400MHz with tight timings and lots of volts it doesn't mean that the platform will be fully predictable at 1400MHz using any memory you will throw at it. I'm not even fully sure if my 1333MHz results are 100% reliable, lol.
If you are IMC limited(23 code at 2800 let's say) then you won't pass that no matter what memory you throw at it.
If the imc is up to the task basically you have a shot with any memory that is known to be able to reach 2800.Timings and voltage are another matter,eventhough that still depends on every chip,one 3770K i had will clock my 2666c10 to 2800 9-12-12 with 1.90V set in bios and be 32M stable,other will do that with 1.88V in bios.Same ambient temperature.
BUT WHAT I WANTED TO CLARIFY,THE MOTHERBOARD ITSELF IT'S NOT THE MAIN FACTOR HERE,unless you have ecs,biostar and bad support.
I can do 2800 10-12-12 with 1.65V ,will that make me a genious and the thing that i throw 1.9V to reach 2800 9-12-12 will make me a idiot?
There are lots of smart and helpful guys around(dumo,splave and others...) who really know what they do and i really appreciate the things they post, but i cannot agree with guys like websmile who blames the motherboard because he can't clock his memory....
A good mem clocking board will work effectively with every brand, my board can?t as the difference on the corsair, and not only on the 2400c9, between memtest stability and win 32m is simply too big - and I don?t need your precious advice, dear friend, as I can clock other samsungs easily at 1400 c10 at normal voltage - you may remember, we had discussion about corsair before, as 2666 c11 did not boot 2800 1t and other hynix cfr easily did.Fact is, I can easily clock the 2400c9 at 1400 10-12-12, but not at the voltage they normally should need, because obviously compability between board and memory disturbs better result - and towards your question, using more voltage than needed surely doesn?t make you a genious
