Your results show more spread, but are in the same direction as Martin's results.
See post #134, 5Noz is being discontinued, my new waterblock has higher thermal performance
You see what you did there? You got between me and the coffee, now this creates a SITUATION!
Any ETA for the new one ?
Wasn't martin's test with the 3930K? I believe he was suggesting that different cpus favor different blocks due to the different amounts of bow required by the IHS's. This could explain it or it could be not waiting long enough for loop temps to stabilize but I doubt it because your H20 temps look stable.. I'll be doing a similar apples to apples with the sniper, 5Noz, raystorm, rasa and EK HF w JP6 soon but with the 3930K probably with indigo xtreme (assuming I can afford enough of it - this will take out any mount or bow effects hopefully), so hopefully we'll get to the bottom of this.
My reviews live here: www.extremerigs.net, you can also find me on facebook.com/extremerigs, youtube or even effin twitter
Project Thief - SB-E and Gulftown in one massive watercooled build, 9 rads, 2 cpus, 5 gpus, 2 psus, 8 pumps
last row of my diagram in l/h
After all DetroitAC is right. If you compare martins results of EK Supreme HF, Raystorm Copper and DT 5Noz my results are almost the same on socket 1155. So there seem to be no general difference in performance on sockets 1155 + 2011. But I was a little bit confused forecasting the results because I never noticed martins results of the EK HF in comparison to the Raystorm Copper. I would have expected the Raystorm Copper to perform better than the Supreme HF on socket 1155. And accordingly the 5Noz would have been better than the Supreme HF and the Mips block. But this was pure theory based on false expectations. That´s it.
Just need to decide what setup to put it on....
Thanks DetroitAC
to replace my 5Noz with this or not...
if only it came in white, and I wanna see temps
is the inlet and outlet off centered for aesthetic purposes (placement for compression fittings) or is it actually optimal thermally for it to be in this orientation?
how much better is thermal performance?
Inlet and outlet are spread mostly so that fittings will be easy to use. As far as I know there are not any fittings that are incompatible. To me, that's the way it should be.
The outlet needs to be far off center to clear the large nozzle, and the inlet is spaced about the same to make the block look balanced and give extra fitting room.
I'll start a new thread for Sniper with some pictures of the internals as well as my test results which compare Sniper to Apogee HD and 5Noz. I'd always like to do more and better testing, but I'll share what I have...
With all those compression fittings I wonder if you are negating the strength of such a high flow block like the 5noz.
What DDC are you using?
I am curious... there is also the concavity issues ...but by tim it appears you have average contact. (what tim?)
The main reason why I am wanting custom DT blocks for my G34 system is everything I have seen puts him on par performance wise and leagues ahead on flow....
When you are doing 4 cpu blocks + chipset and 2-3 rads... High flow will take on par performance and bring it ahead...
Patrioteagle: configs like 4 cpu blocks and alike might also mean selecting of favorable loop configurations to move results ahead. Most will have one cpu block anyway. I wonder what might be the reason for worse results for scamps vs martin's. I'd try to dig into mounting pressure/bow ineffeciencies/differences, if TIM paste was used. If it was something like IX, then probably that was not the culprit.
2600k vs 3930k = Apples & Oranges in mechanical contact needs. Also naturally block with low restriction loose more flow rate with additional restriction than blocks with higher restriction so there is some truth to the restriction condition sensitivity. I have always tested in a cpu only plus triple row rad plus 35x pump at 100% for a max performance look but that doesn't represent a multi block complex condition very well. As always the more people who contribute results the better as it gives you a broader set of conditions.
The new block sounds exciting, wish I had the time to test this as well as a few other new ones coming out, but I won't until this fall/winter. Hopefully we can see more excellent testing like scamps provided coming from the forum members to vet out performance on these newest additions..
Have a look at the flow rates. Far enough to get proper results ...
It´s a DIYINHK-modded DDC (12 W) but even with reduced rpms. I am one of Waterlogged´s "Euro-Testers", prefering silent systems more than the remaining 0,5 K with Triple-DDCs
Sounds like your holidays become boring already You are welcome
A shame it's discontinued, really nice restriction values.
Really wanted one
The Ninja seems to be slightly better then XSPC Raystorm but the 5Noz is almost like a radiator.
