Page 4 of 7 FirstFirst 1234567 LastLast
Results 76 to 100 of 166
Thread: DT 5Noz waterblock
  1. #76
    Jun 2006
    Northville, Michigan
    Yeah, hide the nozzle was a decision I thought hard about. The nozzle is really easy to duplicate, you just see a picture and you have it, no need to get a sample and measure. I have no doubt competitors will catch up and some will use the same idea but implement in a different way. I am only delaying them by a month or two, but for me those few months equate to money. My guess is the nozzle will be public in under amonth from now.
    You see what you did there? You got between me and the coffee, now this creates a SITUATION!
  2. #77
    Sep 2007
    Coimbra - Portugal
    Btw it's all fixed with the webshop now. Thanks for fixing it in such a short notice
  3. #78
    May 2008
    Miami,Fl
    I guess patenting it is out of the question?
    Looks nice, I might get one when I do my next watercooling upgrade. Good luck on the business venture
    | Asus P8p67- Pro | Intel i7-2600k | 16GB G.Skill DDR3 1600mhz |Ati 5870 | Asus Xonar STX | Corsair AX850 | Raid 0 2xCrucial M4 128gb SSD | 2xWD20EARS,3xHitatchi5k3000 |
    | Coolermaster ATCS 840 | XSPC Rx360 | 8x Scythe Gentle Typhoon AP-15 | Swiftech Apogee XT | EK-5870 | Laing DDC 3.2 +Ek X-top V.2 | Ek-Res 150 |
    | Aquaero 4.0 with Powerboost | Bitspower Shinny Silver Compression Fittings | Primochill LRT 7/16 Blue |
    | Dell U2410 | Klipsch Promedia | AKG K702 |
  4. #79
    Jul 2011
    San Diego
    I hadn't seen any photos of the thumb nuts before - so here's a photo from my build:
    The actual block itself is pretty large - probably in order to fit the 5 nozzles, much larger than most other blocks I've seen. Ignore the barbs, they are just place holders.
  5. #80
    Sep 2007
    Coimbra - Portugal
    I've to look for sume thumb nuts as the ones that martin used, since I don't find those plastic ones that pretty.
  6. #81
    Nov 2008
    Stren, what were you using before? Can you post your performance increase once you get it running?
  7. #82
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    modster: i doubt performance change will be THAT noticeable. Temps are on par with the best, but top blocks from all the companies are within 1-3C. Flow resistance is halved from next best .. but it's not the only block on loop and often importance of flow is overestimated. So imho it's not so much worth to upgrade existing if you already have some of top blocks (EK HF/CPU-360 or 370/Kryos/Apogee XT or HD/XSPC Raystorm), but simply consider it as the currently best block out there for your next purchase/build.
  8. #83
    Nov 2008
    Quote Originally Posted by churchy View Post
    I agree and that's why I want to see how the block performs in a restrictive loop. I can see stren has quite a few blocks and I am assuming he is running all his blocks in series with one single loop. I am interpreting the test result a little differently than most people here and think low restriction may not be a good thing in an already restrictive loop.
  9. #84
    Feb 2007
    with this mounting system, is the only way to get consistent pressure across the four screws is to tighten to the maximum?
  10. #85
    Jul 2011
    San Diego
    Quote Originally Posted by modster View Post
    Modster - I'm actually running two loops on that board - it's a workstation build and cpu clock matters the most, so the cpu get's its own loop with a mora 140x9 rad. The motherboard/ram/gpu will get it's own loop. On the other half of the case I have a 990x and 3 gpus which will be on one loop, I have another 5Noz for that. I will be doing some temp testing - but given Martin's results I expect them to be within the noise floor of my unscientific setup
    See the link in my sig for the build if you want to see more.
  11. #86
    Jun 2006
    Nozzle pictures have been posted elsewhere, here are some that Martin took
  12. #87
    May 2004
    Aland Islands, Finland
    Wow, love it! Very interesting design
    Will no doubt grab one if they ever are sold in EU (tax/duty is real messy for import here)
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
  13. #88
    Banned
    May 2009
    Melbourne, Australia
    lol. of course its high flow. there's nothing stopping the flow.
  14. #89
    Jun 2006
    "Artwork" of the flow paths
  15. #90
    Oct 2011
    Ukraine
    DetroitAC
    Very nice work!
    This is very good so far are located enthusiasts looking for new ways and opportunities. Interesting idea. Waiting for repeating units in the series
    INTEL CORE i5-2500K/ASUS Z68 MAXIMUS IV GENE-Z/G-SKILL SNIPER LV 8GB DDR1600 Dual/POWERCOLOR 6970 LCS (1000/6000)/COOLERMASTER COSMOS S 1100/THERMALTAKE TP 750W
    WC:CPU:XSPC RAYSTORM/VGA:EK FULLCOVER 6970/RAD:WATERCOOL MORA 3 PR0 9X120/PUMP:2XLIANG DDC 1T(DIYHINK)+EK DUAL DDC TOP V2/RES:EK MULTIOPTION X-RES 250 ADV/AC AQUAERO 5XT+WB+4 IN LINE T.SENS+FLOWMETER/FIT:ENZOTECH 13/19 BLACK/XSPC 13/19 WHITE TUBE/9X ARCTIC COOLING F12 PWM
  16. #91
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    DetroitAC: But i wonder WHY you still get good thermal efficiency with THAT LESS flow concentration? Weren't others getting efficiency with concentrating flow via their jet plates right above core below IHS? Yes, they can also easily get flow resistance down by eg. cutting similar 5 wide cuts in jet plates of their blocks, but usually it will result in worse thermals then your block (at least from what i vaguely remember from skinneelab's EK HF least resistant plate test somewhat in between your block and best performing p#1/p#6 plates with most pressure drop). They can shift pressure drop/cooling efficiency ratio to different value if they wish for, but i don't get how you managed to get ratio itself that much better then others, and imho this nozzle system is not the answer, as it is simply parallelized/wider/lesser pressure drop waterflow path with less concentration. Or in other words imho with making your block more resistive (eg. closing two side nozzles) it's efficiency (flow resistance too though) has room to enhance cooling even more, while keeping flow resistance at least within EK HF's levels.
  17. #92
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Who cares, as long as it works!
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
  18. #93
    Apr 2005
    It looks to me like it's working on a simplified (and more open) Cuplex XT Di concept. He's getting the entire wetted area to give up heat with his version, though-it's really a quite ingenious idea. It's quite a concept-one I wouldn't have just stumbled across.
  19. #94
    Jun 2006
    There are a few things about this concept that are different than just cutting more slots in a jet plate.
    The flow strikes a lot of fin leading edges, heat transfer is excellent at the very turbulent zone near a leading edge, this is why high performance air fins are louvered to give thousands of leading edges. Although if you just cut extra slots in a jet plate you get the same number leading egdes. But cutting extra slots in a jet plate just gives the flow a low resistance path at the outermost slot and a high resistance path at the innermost slot, it's not the same as this concept because each of the possible flow paths see pretty much the same resistance.
    The flow from each nozzle is directed downward towards the bottom of the microchannels and then forced to turn and split into two more separate flows inside each fin channel. Then these flows collide into each other at the bottom of the fin channels, more turbulence .
    Next comes the part where the nozzle does something unique, the flow comes vertically out of the fin channels and into the little tunnels of the nozzle where it is able to reach the block exit. So water flow only passes through about 1cm or so of fin before exiting, but there is a lot of turbulence in that 1cm even though they are smooth machined fins.
    I agree with you Churchy, this concept could be "tuned" to get the heat transfer and resistance to many different operating points, the "next" nozzle is what I'm currently developing.
  20. #95
    Jun 2010
    F.Hills, MI
    I Got one and was able to do a little shopping locally at the store...
  21. #96
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    Hmm, so more turbulence from opposite direction flows instead of getting more turbulence from plain speed/concentration in one place as in other blocks? Hmm, sounds possible. I'd also check if your design somehow doesn't help for better thermal contact/pressure then common design.
    As for your next block .. maybe not eliminate side inlets then, but make them all narrower by some 20(?)% and more closely located? Probably some study of cpu core size/form/placement under IHS plate of all the latest generation chips is needed to get more of cooling/turbulence right above him, less - on IHS sides without chip beneath. As i've stated previously, you have big margin of growing flow resistance till you get till next best block, so why not use it to get eg. another two degrees down?
    P.S.
    For bling side of future blocks you may consider All black. Including springs/mounting screws&bolts and so on.
    P.P.S.
    Another idea that might be tried - locating inlet/outlet fittings at non perpendicular angle to block surface? Imho this might allow more close/optimal inlet placement while still allowing the very biggest compression fittings side by side, and reduce flow resistance a bit. Probably harder to manufacture though.
  22. #97
    Sep 2007
    Coimbra - Portugal
    Quote Originally Posted by wez View Post
    Well I got one in Portugal ( Ordered from the online store ) DT was kind enought to help filling the gaps so it didn't got any attention of costumes therefore I got it without paying extra taxes .
    Some photos I took ( I'll show the injection plate since DT did it himself and I think theres no problem in showing it any more ).
  23. #98
    Xtreme 3D Team
    Jan 2009
    Ohio
    Mounting for this block is actually a bit less pressure than standard mounts if I read correctly.
    Smile
  24. #99
    Nov 2008
    DT, how many blocks have you sold so far?
  25. #100
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    Very nice injection plate. I wonder how much blocking the to outer smaller holes will affect temperature and flow...?
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
