Nice looking block, hardware is average definitely think it could improve, but liking the block so far. Nice work.
~ Little Slice of Heaven ~
Lian Li PC-A05NB w/ Gentle Typhoons
Core i7 860 @ 3gHz w/ Thor's Hammer
eVGA P55 SLI
8GB RAM
Gigabyte 7970
Corsair HX850
OZC Vertex3 SSD 240GB
is this publicly available yet?
yup, just ordered mine yesterday!
Still working on my new 3930K overclock, but I figured I'd share some quick and dirty stand alone results. This is with a rather light 35-40lb mounting force (lighter weight springs than provided) that I've been tinkering with as a new test standard (fixed mounting pressure).
Thats a pretty respectable result, especially given the flow overhead available for custom plates.
Easily the most competitive homemade block ive seen in the last 10 years. Great work.
gpu version next please!
Five mounts done,
Now for testing/retesting of other blocks for some comparative data next.
The new 3930K is up and running and cranking out the heat...
Pretty happy about the higher heat load and more consistent mounts too.
Martin, after many mounts did you encounter problems with de delrin mounting bracket?
CPU Intel i7 930 3001A125 @ 4.0 GHz HT
Mobo Asus Rampage III extreme 1208 BIOS
GPU Sapphire HD 5870 XFire (2x)
RAM G.Skill Ripjaws F3-16000CL9T-6GBRH DDR3-2000 (6x2GB)
SSD Corsair Force GT 120gb SATA3
HDD WD Caviar black 1.5TB SATA3
HDD WD Raptor 74GB SATA
HDD WD Caviar 250GB SATA2 (2x)
Storage controller IBM M1015 SATA3 RAID controller
CPU Block Koolance CPU-370
GPU Block Koolance VID-AR587 (2x)
Radiator Phobya G-Changer 360 (3x Panaflo FBA12G12U 120mm)
Radiator HardwareLabs Black Ice GT Stealth 420 (3x Yate Loon D14SM-12 140mm)
Pump Swiftech MCP650 (2x)
Case MountainMods Pinnacle 24
PSU Enermax Evo Galaxy 1050w
Sound SB X-fi titanium Fatal1ty
there were problems with the mounting system?
No, no problems although with Socket 2011..you don't need/use any sort of back-plate since it's already built in. I am also using a standardized set of springs/washers/thumb-nuts so I can better measure mounting pressure (Approximately 35-40lbs) consistently between blocks. I'm using XSPC Raystorm M4 studs, One large metal washer, one small M4 washer, one small black nylon washer, one DD M6 spring (approx 7-8lbs fully compressed), and one DD M6 Brass M4 oversized thumbnut.
The 5Noz came with M4 screws, 20lb springs, and a standard M4 nut. The springs are a bit too strong to fully compress and the standard M4 nuts would require a deep 7mm socket. I prefer using a lighter spring myself to have measurable pressure. I also believe the new 5Noz package comes with large thumb-nuts.
So...no problems, but I am using 2011 which doesn't need a back-plate and I am using my own "Standardized Test" hardware so I can better evaluate performance between blocks and it's faster/easier for me not having to mess around with motherboard removal, etc..
I went the extra step in installing and evaluating "As Shipped" hardware with 1155, but after killing my motherboard and seeing how 2011 doesn't need a backplate, I'm being a bit more conservative/lazy and testing the blocks only this next round using a fixed set of hardware...![]()
Ah. Thanks for clarifying. So curious, if a backplate of another block has M4 threads, can we use that if we think that it's a better backplate?
The black thumb nuts look like they are being taken from tooth paste tube.
When is the full interior to be visible to public eyes? I am more interested in that as @ first glance on Martin chart it looks a lot like old Supreme with ancient mounting kit.
Cmndt. Eric Lassard: What is the most frustrating thing about police work?
Tackleberry: Not being able to carry hand grenades, sir.
Tackleberry - old chart was on a 2600k, this is a 3930k. Temps look average to good, flow looks excellent.
Draft review so far..
http://martinsliquidlab.org/2012/03/...-block-review/
Thanks Martin. Now I need to test this on a 2600K to see how it handles the ihs of the smaller die![]()
Crunch with us, the XS WCG teamPOLITICAL CORRECTNESS:
A doctrine, fostered by a delusional, illogical minority.
Nice review, thanks Martin!
Impressive performance and a new block at that. I guess you have to buy one to see the jet nozzle
Now if IVY would hurry up and get here so I have something new to watercool.
3770K 4.7 w/1.31 - UD5 z77 - Dom 1866 - Corsair HX850 - Intel 520 240gb - GTX 680 - 26 inch Samsung LCD
xspc 360 + SR1 280 + HC 680 + EK sup hiflo
Lian Li A71F
Are there any issues (performance or otherwise) with running the stock socket 2011 backplate?
My reviews live here: www.extremerigs.net, you can also find me on facebook.com/extremerigs, youtube or even effin twitter
Project Thief - SB-E and Gulftown in one massive watercooled build, 9 rads, 2 cpus, 5 gpus, 2 psus, 8 pumps
AMD spiders are available
You see what you did there? You got between me and the coffee, now this creates a SITUATION!
Definately looks better than everyone else's AMD plate.
I'm curious, what are the dimensions of the base?
Anyone bought one of these and had problems with the payment?
Nice review from Martin and wonderful to see it perform for independent testers as good as claimed.
Though imho there was not much need to hide that much nozzle system, as probably any competitor vendor if interested in can buy block itself and study with care locally in person, not from public reviews, but those said reviews because of that suffer a little bit by lacking few interesting photos/details for readers![]()
