Some photos ASUS HD 7970 Direct CUII TOP:
More photos here: OCLab.ru
i like this heat sink
if can put my ek supreme vga hf on it
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
i7 3960X@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC19200C8, Corsair force GT 240go, 2XGTX Titan, MM Ascension, Seasonic X-serie Gold 1250W, Watercooling
i7 3930K@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC17000C9, OCZ Vertex 3 120go, GTX670 DCU2 Top, MM Pinnacle, Corsair AX850, Watercooling
More news:
More info here: OCLab.ru
First version of HD 7950 Direct CU II seems to have a problem with the heatsink :
http://www.hardware.fr/news/12153/as...attention.html
Translated
Huum i was curious to see if it was a 1.12 or 1.17v cores in it... sadly i have not see it in the article.
CPU: - I7 4930K (EK Supremacy )
GPU: - 2x AMD HD7970 flashed GHZ bios ( EK Acetal Nickel Waterblock H2o)
Motherboard: Asus x79 Deluxe
RAM: G-skill Ares C9 2133mhz 16GB
Main Storage: Samsung 840EVO 500GB / 2x Crucial RealSSD C300 Raid0
ROG Power PCs - Intel and AMD
You don't read really well french my dear FlanKi3r :
Not the same PCB than HD 7970 DCII :After 30 minutes of charge, without overclocking, and while the GPU probe delays a low temperature, the system hangs. We raise the test, open case, so as to observe the temperature of the card. Surprised, she quickly climbed the back of the GPU and once it reaches + / - 80 ° C, which probably reduces the effect of fixing the thermal paste, it accelerates to reach over 115 ° C and crashes. The log of the probe GPU shows 70 ° C only.
Olivon,
I don't speak or read French, but a picture speaks a thousand words. The article and your comments indicate that the measured gpu temp was 110C, while the software indicated 70C. And this was at stock clocks?
How wide spread of an issue is this? Was the review card a purchased retail card or a card sent directly from ASUS to the reviewer? After seeing that review, does this reflect larger issues with the card? It kind of makes me wonder if this is coincidence or the reason that the card is not in stock in the US.
Asrock Extreme 4 | 2600K | 16G G Skill | Powercolor LCS 7970 | PCP&C 910 Silencer | Crucial C300 + Intel X-25V + Raptors | D-Tek Fusion v2 | Swiftech MCR Drive 360 | HP LP2475
No problem Sailindawg.
Yes, that's itThe article and your comments indicate that the measured gpu temp was 110C, while the software indicated 70C. And this was at stock clocks?
1st card (Asus review card) got the problem so they don't include it in the 7950 roundup they have done.How wide spread of an issue is this? Was the review card a purchased retail card or a card sent directly from ASUS to the reviewer?
As Asus didn't sent a second sample, they took it one from retail channel and the problem is still there. Thermal picture was done with the retail one.
According to the author's article, the pressure between the heatsink and the chip is too weak and he was able to reproduce the phenomenom by excercising more/less pressure between the two components.
Shame HD7970 doesn't run GTA 4 any better than GTX560ti 2GB
Damn Olivon, I had my hopes up for this card or the Saphire E6 card. I wanted to run three monitors & this card seemed to fit the bill given the display port connectors. My 5870 seems quite challenged to run three monitors with >40 fps. However, I'm surprised by lack of availability of the 7970's. I'm also disappointed by the stock connectors on the reference cards plus the issue of screen tearing using mixed connectors.
