+ Reply to Thread
Results 1 to 2 of 2
Thread: Maximus III Formula and boot from USB device
    Registered User Piospi's Avatar
    Oct 2009
    0
    Hello guys !
    I have Maximus III Formula. Can I install / boot from USB (pendrive) ?
    i5 3750K + EK Supreme HF Full Nickel | Asrock Z77 Extreme4 | G. Skill ECO 1600 MHZ CL7 2x4GB | Seasonic X-Series 760W Gold
    EVGA GTX 480 + EK Acetal Nickel | Samsung 2233RZ
    Samsung 830 128GB | Samsung F3 1 TB | Samsung SH-S222AB
    Xonar ST + H6 | Sennheiser HD 555
    Obsidian 800D | Swiftech 350 |EK-DDC X-RES 140 Acetal | Phobya G-Changer 360
    BQ SilentWings 3x120mm | BQ SilentWings 2x140mm | Zalman ZM-MFC1
    Xtreme Member The Jesus's Avatar
    Jun 2008
    Winter Springs, FL
    15
    Yes. Check the BIOS boot options and change the order. You might also need to check the actual hard drive priority.
    Why yes, yes I do use Koolance..*Flame Wall Inbound*
+ Reply to Thread
