My settings were all correct as i have a pretty good understanding on how the system all works, the bass boost was off and the gain on about 85% with the headunit sub level set to 8+ and the crossover set at 85hz with a 24db drop with every octave. The sub enclosure is around 1ft square (not ported for better accuracy) and hooked up only to one of the two alpine type r 12's due to it not having any where near the sufficient power for both. (wired in 2ohm for 100% power output from amp).
The new kicker with the same settings does well in accuracy its just not powerfull enough, distorts way too early for claimed 500 watts.
