Results 1 to 8 of 8
Thread: Fan controller: maximum watts per chanels Q
    Mar 2005
    Montreal, Canada
    Hi guys,
    I just want to confirm that my old Vantec Nexus fan controller can handle 3x Panaflo FBA12G12U on a single channel (Phobya G-Changer 360 rad). As per MartinM 120mm fans review, at 12v the wattage of a single FBA12G12U is 5.64w. Reviews on the Vantec Nexus fan controller calls for 15-18w (up to 18w per channels). Am I good to go with 3x fans in parallel?
    Thx for your help.
    Kosmic
    CPU Intel i7 930 3001A125 @ 4.0 GHz HT
    Mobo Asus Rampage III extreme 1208 BIOS
    GPU Asus GeForce GTX 770 DirectCU II
    RAM G.Skill Ripjaws F3-16000CL9T-6GBRH DDR3-2000 (6x2GB)
    SSD Corsair Force GT 120GB SATA3
    HDD WD Caviar black 1.5TB SATA3
    HDD WD Caviar blue 1.0TB SATA3 (2x)
    HDD WD Caviar 250GB SATA2 (2x)
    HDD WD Raptor 74GB SATA
    Storage controller IBM M1015 SATA3 RAID controller
    CPU Block Koolance CPU-370
    Radiator Phobya G-Changer 360 (3x Panaflo FBA12G12U 120mm)
    Radiator HardwareLabs Black Ice GT Stealth 420 (3x Yate Loon D14SM-12 140mm)
    Pump Swiftech MCP650 (2x)
    Case MountainMods Pinnacle 24
    PSU Enermax Evo Galaxy 1050w
    Sound SB X-fi titanium Fatal1ty
    Jul 2011
    Kaiserslautern, GE
    is that operating voltage? if so be aware that most fans have a ramp speed when first turned on that can exceed that rating (avg close to double)
    i7 3930@4.5GHz (EK Supreme HF), GTX690@1.2GHz (Koolance NX-690), 128G 4M + 2x128G 4M raid 0, Silverstone TJ07, Custom Enclosure w/MoRa, 18x GT AP-31, 401X2 dual PMP-400
    Jul 2011
    Personally I wouldn't do all 3 on a single channel, 2 at the most. I too have an old Vantec Nexus, used it with a similar to your Panaflos Delta fan for many years. The reason being you're going to be cutting it awfully close _if_ you're in luck and it can do 18W which is the upper range that each channel is rated at.
    Mar 2005
    Montreal, Canada
    Yeah, it's the amperage draw at start-up that concern me. What if I turn it down to 5 volts (minimum) the Panaflo channel before firing up the system?
    Operating voltage between 5v (min) to 12v (max).
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    I've not really found current limits to really be the bottleneck on a controller yet. It seems like heat dissipation operating at low volts is what's the stressing operation.
    Does that controller even have heatsinks at all?
    In general, I wouldn't put more than about 1/3rd of the rated watts for practical use and just watch the heatsink temps. I've killed my fair share of controllers and don't have much confidence in most ratings at all. I haven't really found one yet that's been capable of running the full load at low volts without beefing up the cooling.
    Mar 2005
    Montreal, Canada
    No heatsinks on that controller, it's old (bought it in 2005).
    Ok, I'll use one Panaflo per channel and use directly psu molex (12v) for all my Yate Loon's (120mm high & 140mm medium) they are quiet for me at max rpm anyway.
    Thx guys.
    Jul 2011
    Kaiserslautern, GE
    side note: you could always build your own, or mod your current controller with a larger amplifier/transistor (change the 3A device out for a 5A device from radio shack for example)...or buy a transistor heat sink.....if your mechanically inclined.
    Mar 2005
    Montreal, Canada
    Yeah, I'm a diy kinda guy. I changed the blue leds for red ones on the controller. I'll look into it. For now, I just want that computer to start lol! Thanks.
