Results 1 to 6 of 6
Thread: 2 X PMP-400 in Dual Pump Reservoir?
    Jul 2006
    Nova Scotia Canada
    I have two Koolance PMP-400's, one from 2008 with the red impeller (DDC2) and one purchased much more recently, DDC 3.25. from what I can find the specs are pretty close.
    Opinions on if they will play well together in a dual pump reservoir, such as the XSPC Dual 5.25" Bay Reservoir for Dual Laing DDC?
    i7 860, 20 X 200 = 4.0GHz at 1.35V, MSI P55-GD85, 2 X 4GB KHX1600C9D3K2/8GX, GTX 590, 2 X Corsair Force 3 120GB SSDs in RAID 0, 4 X Barracuda SATA 7200.10 250GB RAID 0, 2 X Barracuda SATA 7200.11 500 GB RAID 0 for Back Ups, OCZ ZX 1250W, Z-5500s, LG Blu Ray Player/DVD Burner, Koolance CTR-CD12 Fan/Pump Controller, Windows 7 X64 Home Premium, HAF X. Vision Quest 24" WS LCD, Optoma H66 Projector
    Cooling: Thermochill PA120.2 GT AP15 in push, DC3.25/XSPC Res top, Apogee Xt Extreme, XSPC Razor, Coolgate CG-240 GT AP15 in push/pull, MCP35X.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Mixing similar pumps is fine. I've even mixed DDC and D5's together in testing and have yet to see how that could ever be a problem. Each pump produces pressure differential that's all and there is no mechanical tie between two pumps. The only way I could see mixing being bad is if the resulting flow rate ran one pump beyond it's operating curve.
    About the only thing I would worry about is heat dissipation of the pumps. Two pumps in series does raise the system flow rate and if you start pushing beyond 2GPM the heat of DDCs increases fairly quickly.
    How much heat depends on how much restriction, the less restriction the more heat.
    You might consider adding a heatsink or at least a fan to blow over the bases would be my suggestion.
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Wow. Honestly didn't think heat output of the pump would increase that much.
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    High flow is High Heat in DDC land...
    Slightly different test, but..
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    And here is a latter test looking at cooling with the swiftech heatsink:
    I still have a Koolance heatsink I have yet to test in the testing que, but cooling is not a bad idea.
    Jul 2006
    Nova Scotia Canada
    Thanks for the info. I don't really need two pumps, but, I do like the redundancy factor. I would be running the pumps at 9v as opposed to 12v, so, there would be some reduction in heat. Good info for me to consider, and I appreciate you taking the time to respond.
