Black Ice GTX Extreme 360 questions..
It,s a good idea use this rad with a Nidecs 1850 in Push-Pull or are better options today,s to get perhaps better results ??? Maybe 1850 is not quite enough for this rad,
it should be enough. high finned rads like gtx lead starting from 1400rpm with single row of fans. in push-pull probably even from lower speeds. also GTs probably will be @1850 as loud as majority of fans @1400. Go for 'em.
Ok, Churchy, Im using now a GTS Lite ( 3 cm thin) with the Nidecs 1850 in push-pull. The rpm,s drop from 1850 to 1650 and I use shourds only in the pull fans.Thats the reason for ask.
- You may not post replies
- You may not edit your posts
Forum Rules
