Some expert opinions please...
I'm about to put together a new system. I'll be cooling a clocked 2600k on a Z68 (P8Z68) with two RX240's (don't ask me why 2 x rx240, I'll show you eventually) and whichever next gen dual gpu is fastest (or available) with an RX360. Rads are all in the case and I will be pulling air inside as well. With all the rad capacity I will have, I intend to run my fans quietly, even when gaming (unless I can't), which of course, means there will be only a minimal amount of warmed air flow through the case. I will have a 120mm exhaust. I could mount my bracketed 80mm fan to blow over the vrm.
How warm is it going to get in the box? The southbridge should be ok but will the mosfets get to hot? I know they're supposed to be good to 120c but, in a low (warm) air flow environment, is this going to be enough?
