Thanks guys
The displays are very accurate thankfully. I have had one of these be 5c off so it's nice to get a pair matched. I mean, these are more about reference to boot up the pc and there's 4 K plugs out the back for real diagnostic measuring but having them be this close is great.
One is around 1-1.5c warmer than it should be. The other is more like .5 colder than it should be.
Since I'm not that picky about these that's fine with me. Cold and warm about the same variation now.
I'll have to keep that issue with power in mind though. The cascade that has one of these reads off but I also ran the wire by the pipe for a few inches. If in future I make sure I get distance from the pipework maybe I won't get interference and they'll be more accurate. At least they don't blank out like the 5v displays were. That was really annoying
Can't lie, dealing with captube problems can be a real nightmare.
For the brazed or soldered stuff it's easier to just scrap the pipe and cap and replace it, whether you 'tag' the new captube in or run it all the way to the filter. Can lead to a lot of waste when you're playing with tweaks and stuff but I think it's worth it for the advancements you can find. I use and scrap a lot of captube. Thankfully it's not that expensive.
It's hard to deal with evaps when you have a bad or blocked cap. Mostly it's easier to remove the evap from the system, drill and new hole and clean up blasting out any bits that drilling leaves as well as filing/sanding the hole so no little bits can break off and go into the system. Run the new cap and braze as normal, purging of course. More or less as much work as brazing a new head.
I had another prepped evap with a captube tail and I just tagged it in. Over the years I've gotten good at joining captube, so it's not as big a deal but joining can be tricky. Easy to overbraze/heat and end up with blocked cap.
Was pretty scary on the other evap too, only had 1.5" of cap tail to work with, if I'd blocked it I may not have had the length to redo it again and would have had to drill and run new.
Gray
