So people say it's been quiet and I agree. There's also been a lack or particularly different custom stuff being made.
So here's something that hasn't been done, or at least not for a long while.
I'm converting a mach 2 case. I have a Lian Li kit for it, as well as front and top panels. So I'm chopping them up and making something pretty and functional.
He's got a pair of 6990's. They're a dual chip card, and it was originally just a dual head project, but with a dual card setup, that means 4 cores to cool
He really wants it pretty and with what I have it's looking that that'll work out well too.
So the project is a pair of dual head 1/2hp rotaries in an extended mach2 case with lian li faux front and top kit, so it's going on top of his case and the flexy's are going down.
Each head will likely be putting up with 300w at worst, depending on the OC. I've seen specs stating 300w stock per card, so I'm guessing this is 600w per unit max.
Most testing will be at around 240w per head though. Makes more sense to me to get a figure closer to the average-high range of OC. Won't be going too cold for the gfx so it's not a condensation/insulation headache, and it seems like around 50w idle per core, so 100w idle per core heat dump to the card means heater pads shouldn't be a requirement.
I'm aiming for around -10c per head idle temp evap. The core idle wattage + memory should make the card sit above where moisture is condensing, and the backplate foam will be there to help.
So specs...
1 x 1/2hp Rechi Rotary 31LRA
1 x 1/2hp Rechi Rotary 28LRA
(slight size difference, but I'll tune it so they give around the same temps. Higher spec on the primary card set)
2 x @itor gpu evap
2 x Chilly1 gpu evap
I'll likely use the better compressor on the Chilly1's. The @itors are a bit better, so will balance out I hope. A couple degrees difference will affect nothing.
2 x half condensors from a 12k btu 3 pass HE model. Real nice condensor, need to chop it and rebraze ends on the cuts. Paint afterwards.
12" tall, full Mach case width. 2 x 25mm fans per condensor for space.
It's a tight fit, and esp with the dual lines out, will split the lines for dual heads closer to the ends to save space and balance LP.
Small SLHX braze design. No room for real SLHX's but I can do the brazing to the Discharge post-filter/pre-captube or pre-filter/post-condensor. Prefer after the filter. May go dryerless on this one.
Gas is still to be determined. Will do a propane test and see what load = what temp per head so I know if I have to go down to 134a.
The rotaries are 11" tall. Case will be 13" tall. Space is non existant so it's all going to be very minimal.
Air in the back and front, out the top.
Window to be modded in, so I'll have to choose some paint schemes. He wants polished copper pipework though
Pics of the process so far, it's early days on it.
So I've been chopping the panels so I get a good front fascia match. Some paint to see what the final will look like, but it's just a mockup. Real paint later.
Need to cut down to a 13" front, and that should get that blank between the hole patterns pretty even, so less to make the seam obvious.
Still have to extend the case once I have the exact measure of the front.
3 of the heads are already prepped in the 'all in one' project from before which is cool, only the one to braze.
But I have to make some hold downs for them all. So I'm making up some ideas of how to do that easily and still have a nice hold down.
I'll keep posting as progress is made. I have a plan but I also have a lot of possibilities for colours, shapes, mesh types, etc. So many little things, the cooler is the easy part
Gray
