5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
How about black powdercoating on the stainless steel?
Powdercoating doesn't cause corrosion, does it? (correct me if I'm wrong)
lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
*phone rings*
Friend: Do you have a spare PSU lying around?
Me: No why?
Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
Me: what PSU was that again?
Friend: Antec 480w
Me:........
Correct... it's akin to glazing pottery. You spray the stuff on as an electrically charged powder and then bake it, melting it into a cohesive coating. I love the stuff, personally.
Excellent!
Nice one EK hope its out sooner rather than later
Personally I'll be waiting to see what the competition have to offer first before I take the plunge for EK (once bitten twice shy and all that!)
Looks arent as important as performance is tbh, for me.
4960X@4.7 | Asus RIVF | 16Gb@2400 | 256Gb 840 Pro | R9 290 | AX-860W | 540Air | Custom W/C
Quick test. This is an older version of the block, newer version (release to manufacturing) has even better performance - flow & cooling wise!
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
^whats the point of that screenshot? we dont see load temps or a max OC (limited by CCC), and weve seen 1125mhz benchmarks from plenty of other sites.
2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
XS Build Log for: My Latest Custom Case
The point of this screenshot is to tease you. Don't be so grouchy :P
EK Water Blocks R&D
ekwb.com
You can see a 3DMark score and the max temp during that benchmark = 29°C?
A bit off topic but still in relationship with HD 7970. We have manufactured 0.5mm copper spacers for EK-VGA Supreme HF series water block (of for that matter any GPU water block and/or phase change cooling evaporator/LN2/DICE pot). They should be available for sale in about a week. Cheap too!
EK Water Blocks R&D
ekwb.com
First real test:
Loop:
EK-FC7970 prototype block
360 RAD
3x Yate Loons D12SL
2m 12mm ID tubing (1/2")
D5 Vario + EK X-TOP V2
EK-RES X2 250 Advanced
EK-12mm High Flow fittings
Measuring equipment:
- Greisinger GTH 175/Pt, calibrated
- Voltcraft IR-800 20D
- Digmessa digital flow meter
Furmark ran for almost five hours!
Cards running at stock volts yield the following results:
Tgpumax = 41°C
Th2omax = 30.7°C
dTmax = 10.3°C = ~ 10°C
Overclocking the card to 1125/1500MHz (GPU/RAM respectively) @ 1.250V yields:
Tgpumax = 42°C
Th2omax = 31.1°C
dTmax = 9.9°C = ~ 10°C
The dT does not increase not even at these circumstances. Cooling engine holds fine!
Also the VRMs are noticably colder than we are used to. The hottest measured temperature was ~ 49°C (behind the MOSFETs, back side of the PCB), highest logged temperature was 50°C after 5 hours of Furmark.
The best thing about the block - flow rate. It surpases our flagship CPU waterblock EK-Supreme HF by a large margin. You can easily run four of these cards out of one mediocre pump!
Attached is the hydraulic curve for EK-FC7970:
Serial production - block in the making. Made in Slovenia - Europe:
EK Water Blocks R&D
ekwb.com
You can sure sign me up for two. Any ETA yet on when they'll be shipping?
Intel i7-970 4.5 GHz 1.25V | Asus Rampage III Extreme | Corsair Dominator 12GB | Asus 7970 DCII Crossfire | Western Digital 1TB Caviar Black | Seasonic X 1250 | Lian Li X2000-F | Microsoft Windows 7 Ultimate x64
EKWB Supreme HF | EKWB RE3 Fullcover | EKWB Ram Dominator | EKWB 7970 DCII Full Cover | Swiftech MPC 655 | EKWB Serial D5 Top | Watercool E.K. MORA 3
Hi Nigel,
hehe, great! I think the first batch should be available some time next week, but not later than on friday.
Best Regards,
Niko
EK Water Blocks R&D
ekwb.com
Already ordered 4 from my favorite retailer.
Going Quad-Fire 4X 7970.
i7 3930k EK-Supreme HF - Asus Rampage IV X79 - QUAD-Fire: 4X Asus 7970 EK waterblocks - 4X4GB=16GB RipjawsZ 2400 CL9 - Crucial C300 128Gb M4 128Gb 2x Intel X25-M 160GB 3X Seagate 2TB - Mountain Mods Extended Ascension + Pedestal 24 - Dual-PSU: Antec HCP-1200 + Corsair AX850 - EyeFinity 3X 30'' LCD - Windows 7 64
tibor any chance of getting a shot of the plate itself?
Id like to see the channels...
Looks like a nice block tho...
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
No need for trolling in this thread. Warning has been sent.
Always lol @ milk cannons on CNC machines
-PB
-Project Sakura-
Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
Got my card today, can't wait to order the block 100% stock cooling is very loud!
i7 3960X@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC19200C8, Corsair force GT 240go, 2XGTX Titan, MM Ascension, Seasonic X-serie Gold 1250W, Watercooling
i7 3930K@5ghz, Asus Rampage IV Extreme, 8gb Gskill RipjawsZ PC17000C9, OCZ Vertex 3 120go, GTX670 DCU2 Top, MM Pinnacle, Corsair AX850, Watercooling
Project Elegant Dreams
CPU: Intel 980x (3005F803T) @ Stock , Mobo: Rampage III Extreme, Ram: 24GB Corsair Vengeance 1600 C9 1T 1.51v GPU: SLI EK'd Vanilla GTX580, 0.875v @ idle.
Sound:Asus Xonar Xense w/Sennheiser PC350
SSD: 2x OCZ Agility 3 120GB RAID-0 on ICH10 Storage: 2x1.5TB Hitachi 5K3000, 1.5TB WD Black, 1TB F3, various other HDD's Case: Obsidian 800D, PSU: Corsair AX1200,
Water Cooling
Main Loop
EK Supreme HF
EK GTX480 blocks on EVGA 580s
MCP355 and MCP35X in serial
Dual BlackIce GTX480 Rads
metal plate looks like crap to me. i don't get plated blocks because i hate the silver bling look. that plate is gonna force me to buy another manufacturers block and i'm a diehard EK fan. FML
1300MHz, 1.25Vgpu Furmark stable
Th20max = 32.3°C
Tgpumax = 43°C
dTmax = 10.7°C ~ 11°C
EK Water Blocks R&D
ekwb.com
Water Cooling
Main Loop
EK Supreme HF
