+ Reply to Thread
Page 1 of 5 1 2 3 4 ... LastLast
Results 1 to 25 of 102
Thread: GIGABYTE's mobo X79-UD3 happens self-ignition and burning!
    Xtreme Enthusiast sxs112's Avatar
    Mar 2004
    Taiwan
    0
    Today an end-user (japan0827) who comes from Taiwan.
    He unboxed the X79-UD3 mobo yesterday but when he wants to keep going
    test about the mobo,suddenly amazing event happened!
    The mobo X79-UD3 happens self-ignition and burn by it self!
    He uses video camera and pictures capture to record all evidences!
    PIC
    Video
    Please have a look! and original link!
    http://www.xfastest.com/thread-69517-1-1.html
  2. The Following 2 Users Say Thank You to sxs112 For This Useful Post:
  3. #2
    Memory Addict eva2000's Avatar
    Aug 2002
    Brisbane, Australia
    0
    woah... that's crazy!
    X79 VRM need cooling heh
  4. #3
    Xtreme Mentor SKYMTL's Avatar
    Aug 2007
    9
    IMO, that's sort of his own fault, particularly when we don't know the backround story (ie: voltages, clock speeds, etc).
    ANY heatsink is in place to dissipate heat through the use of airflow. In a computer case, there's airflow moving over them which is why most people clue into the fact that out of case testing needs the same type of air movement.
    See EVA2000's response above. That's the SMART way to do open system testing. In the video above, you see the clueless way.
  5. The Following User Says Thank You to SKYMTL For This Useful Post:
  6. #4
    -100c Club tiborrr's Avatar
    Jun 2005
    Slovenia, Europe
    64
    Yeah, no airflow over the VRM results in toasty consequences
  7. #5
    I am Xtreme Hondacity's Avatar
    Aug 2008
    110
    its not his fault. stupid gigabutt product.
  8. #6
    Xtreme Addict Andrew LB's Avatar
    May 2003
    Peoples Republic of Kalifornia
    6
    Quote Originally Posted by Hondacity View Post
    It's like blaming Intel for a CPU catching fire because you didn't put a fan on the heatsink. Or perhaps suing McDonalds after dumping a hot cup of coffee in your lap. Thank god a higher court overturned the verdict and she didn't get a dime of the $3 million award.
    Laws that forbid the carrying of arms . . . disarm only those who are neither inclined nor determined to commit crimes . . . Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than to prevent homicides, for an unarmed man may be attacked with greater confidence than an armed man.
    ― Thomas Jefferson, Complete Jefferson
  9. #7
    Xtreme Addict billdavis's Avatar
    May 2006
    Colorado Springs
    14
    Ive heard the McDonalds coffee thing for years and didnt know the woman didnt get the money, so thats cool!
    if he didnt have airflow on his MOBO then it would be an unfortunate result of natural selection
    De oppresso liber
    Nous Defions
    E pluribus unum
    no matter where you are There you are, you are what you are where you are when you are, you are who you are no matter when you are.
    A weak life is much worse than death!
    cpu PXA310 memmory 197.36mb
  10. #8
    Xtreme Addict screwtech02's Avatar
    Mar 2005
    32
    Wonder how the "warr return" will work out on this?????
    Gigabyte X58 UD4P
    I7 920@4.2
    24gb Patriot G-Seris PC3-12800
    Asus Direct CU 5830 Tri-Fire
    2 320gb seagate hybrid drives (o.s. array)
    4 320gb samsung F1's (Game Array)
    X-Fi Titanium
    Custom watercooling setup
    (proc,chipset,vid cards)
    Windows7 Ultimate X64
  11. #9
    Aug 2008
    110
    Quote Originally Posted by Andrew LB View Post
    the motherboard had a heatsink.
  12. #10
    Aug 2011
    14
    Ever since time begun it has been known amongst overclockers that if you use water cooling you have to provide additional airflow around the VRM area, and if you are benchmarking or stability testing then are are looking at even greater load and heat which requires even greater VRM cooling.
    What happened to that guy is a common mistake that newbies make.
  13. #11
    Xtreme Enthusiast defect9's Avatar
    Feb 2009
    Carson City, NV
    21
    I'd say it was more likely a faulty vrm or whatever that smd that blew off is (can't remember if brown smd bricks are resistor or capacitor).
    Or, the fact that its a UD3, not a UD7, and may have been pushed a bit harder than it should have been without a fan on the VRM (as people have already mentioned). I'm not seeing this as being the fault of the manufacturer per-se. It's like me putting nitrous in a honda civic and expecting it to be fine (the analogy being- even though I have some cursory knowledge, I'm a noob at adding nitrous and the honda civic is an entry-level vehicle not made for those sorts of stresses).
    i7 2600k, 8GB 1866Mhz DDR3, GTX560 Ti, Gigabyte Z68XP-UD4, CM Cosmos 1000 Case, and some green crap everywhere.
    Quote Originally Posted by Alexandr0s View Post
    So you're saying I could use my own pee as coolant?
  14. #12
    Aug 2002
    Brisbane, Australia
    0
    most of the time the manufacturer would install heatsinks with them intending to have some air flow of some kind usually from case fans etc
  15. #13
    Aug 2011
    14
    Yes the heatsink will absorb the heat at the start, but once the metal reaches the same temperature as the heat source, there will be no cooling from the heatsink unless air blows at it to remove the heat.
  16. #14
    Xtreme Enthusiast noobzed's Avatar
    Jul 2006
    Marseille, Fance
    5
    defect board out of the box maybe, it not supose to be but sometimes it happen, no luck ...
    The Devil's Reject
  17. #15
    I am Xtreme BeepBeep2's Avatar
    Jan 2009
    Ohio
    361
    Quote Originally Posted by ice_chill View Post
    http://en.wikipedia.org/wiki/Convection
  18. #16
    Wanna look under my kilt? K404's Avatar
    Jun 2005
    Glasgow-ish U.K.
    3
    Interesting set of comments regarding PWM cooling.
    Has anyone ever seen a statement on a mobo box (ANY vendor) that says extra airflow IS needed? If the cooling is a must-have, why is it not included? Top-end GPUs don't come with passive heatsinks, expecting the user to add their own fan because it's so obvious.
    I hope i'm coming across as devils advocate.
    you sigged that?
    why?
    ______
  19. #17
    Xtreme Legend dinos22's Avatar
    Mar 2005
    Australia
    37
    i've sent him a message asking for the bios settings used.
    hear hear
    Team.AU
    Got tube?
    GIGABYTE Australia
  20. #18
    Mar 2005
    Australia
    37
    lol did anyone click on the links in his video description. He even did a really nice photochop with flames in one of the Taiwanese forums .... righttttttttttttt
    Team.AU
    Got tube?
    GIGABYTE Australia
  21. #19
    Jan 2009
    Ohio
    361
    I feel it's his fault, but then again...most high end boards today (save MSI) have had functional VRM over temp shutdown...
  22. #20
    Aug 2011
    14
    Quote Originally Posted by K404 View Post
    Not on a Mobo box, but I remember I had ASUS P5NT Deluxe socket 775, it came with an additional clip on fan for the VRM heatsink, it had a warning that the fan needs to be installed if water cooling is used.
    But another point is Mobo makers don't need to say that, it says in the stress testing tools that excess stress will be applied and components can be damaged, a warning like that should make you research what it's about and how to stress test safely.
  23. #21
    c[_] STEvil's Avatar
    Nov 2002
    Alberta, Canada
    20
    hmm...
    I see nobody has commented about how USELESS the VRM heatsinks usually are.
    They often make poor contact and the TIM can act as an insulator if its too thick or the motherboard bows due to poor isntallation methods.
    With that said, the fault lies likely with a faulty component as there is not a rash of them blowing up yet, unlike the Asus Z7S-WS for example of which there were many that did blow up due to the poor VRM design.
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
  24. #22
    Banned
    May 2010
    France
    0
  25. #23
    Aug 2011
    14
    Quote Originally Posted by kroks View Post
    The most pointless post here.
  26. #24
    Aug 2008
    0
    It looks like a failed MOSFET. I wonder if Gigabyte is using substandard NIKOS MOSFETS in their high end boards. Would love to see a pic of the VRM MOSFETS without the heatsink on it to determine the make.
  27. #25
    Aug 2008
    0
    I can't belive Gigabyte is using this lousy transistor in such an expensive board.
    Definitely NOT this guy's fault.
    http://www.irf.com/whats-new/nr111213.html
    International Rectifier, IR® (NYSE: IRF), a world leader in power management technology, today announced that its digital power solution featuring GUI-based VR design for fast, real-time tuning and system-level optimization powers All New 3-Way Digital X79 motherboards from GIGABYTE™, a leading manufacturer of motherboards and graphics cards.
+ Reply to Thread
