Page 2 of 7 FirstFirst 12345 ... LastLast
Results 26 to 50 of 175
Thread: Project Thief - CaseLabs TX10-D Dual Workstation/Gaming Build - Gulftown and SB-E
  1. #26
    Jun 2008
    Winter Springs, FL
    I want that case so much!
    Why yes, yes I do use Koolance..*Flame Wall Inbound*
  2. #27
    Jul 2011
    San Diego
    CaseLabs.net if you want to buy - it's not on the webstore yet but call Jim and he'll hook you up
    In the mean time I've been suffering wrist pain after pulling 20 hour days working on CAD stuff. This isn't unusual when I'm forced to use a bad mouse or a bad setup, but my trusty G5 on a bare desk wasn't cutting it. I decided to try a "gaming" mousepad and thought I'd check out a razer deathadder while I was doing it. After a few weeks of it I actually prefer the feel of it despite the construction feeling less sturdy and having less features than my trusty G5. The G5 now gets relegated to the gaming rig as I game less than I work
    Also parts for my lightsabre came in
  3. #28
    schizo
    Guest
    biggest case ive ever seen !
    will be keeping a eye on this build.
  4. #29
    Jul 2011
    San Diego
    Seeing as we're all a bit bored waiting for the case to come home, here's some more hardware:
  5. #30
    Dec 2011
    I'm loving this case and whole project! I was thinking about how I could possibly build something that would fit 3 machines (File Server, Work VM server, Gaming Rig) all into a single WC loop and I think this might be the ticket. I see you even have sketched in the file server board into your drawing -- are you still considering this? If so, how are you planning on managing video, etc for that box - I know you mentioned a KVM - is that still the plan?
  6. #31
    Jul 2011
    San Diego
    Quote Originally Posted by Endgame View Post
    Thanks Endgame, yes that's the end goal, however it's going to take a while to get the fileserver up and running. Everything is exceeding the budget so far, so that's pushing out the full completion date, that and unexpected dental bills For now I'll complete with the two systems and add the file server next spring I think. The case has plenty of room for it!
    For video yes I'm hoping to get a KVM like this, for now I'm running two keyboards and two mice though for the two rigs that I have running. For a file server though you could just run headless and save a bit on the KVM. We'll see
  7. #32
    Jul 2011
    San Diego
    Tease mode activated
    A box arrived
    You said flap
    The largest usb flash drives known to man and some awesome sauce:
    Sometimes the front view is better than the back:
    Opening a door:
    Socket 2011 is bigger than I thought:
    Inside the box is two more boxes:
    - Curiously only a 2x CFX cable, but yet 2/3/4x SLI cables
    - The sata 6gbps cables are black with partly white connectors as opposed to full black for the rest of the cables.
    - The OC key that plugs inline with your monitor doesn't support high res monitors - bit of a fail there Asus. Shouldn't affect me as I can use the USB cable from my other rig anyway
    - It would be nice if the back of the backplate was also black rather than the shiny tin foil like other boards
    And the last tease for the night:
  8. #33
    Jul 2011
    San Diego
    Had some time for another photo session seeing as the cpu doesn't get here for a few days:
    Took the board out:
    Took the ram out, seems to be the fastest I've seen at 1.5V with 4GB sticks.
    Installed the ram, note that the polarity is reversed on each side, which makes sense if they flipped the pinout on the chip.
    The paint job on the fins wasn't that even - some sticks definitely got more coverage:
    Time to take off the heatsink in preperation for the EK full cover block:
    Only the VRM area had thermal pads on the back and front of the heatsink:
    Looks like Asus have moved away from that horrible yellow TIM they had on the R3E:
    The VRM area with heatsink removed:
    Yes one of those sticks isn't properly in, it's fixed now
  9. #34
    Jul 2011
    San Diego
    Chip arrived, motherboard and ram blocks don't come until tomorrow though.
    SSD is actually for my wife's rig. I don't have an ssd on my gaming rig. I only use it for games so I wouldn't see that much benefit from a boot drive. I use my workstation for web browsing etc as it's on all the time. I'd need a 512gb drive or so to cover my games, so I'm waiting for prices to come down more
    Batch on the 3930K is 3152B448, we'll see how it clocks soon
  10. #35
    Jul 2011
    San Diego
    Suddenly a wild EK party!
    Nickel plexi because I want to run some red dye (on special occasions only for all you dye haters out there)
    Finished cleaning the TIM off the south bridge only to find a piece of tin foil with more TIM underneath. Weird.
    Pretty easy to install when the block is in two parts, the single piece blocks are much harder:
    VRM area:
    Full board:
    and one more:
    That's all for now
  11. #36
    Jul 2011
    San Diego
    No comments? Come on peeps!
    With ram blocks, the fittings aren't the final ones, just more for planning. I'm working with Monsoon free to see if something special will make the tube routing super clean
    the ram blocks remind me of battersea power station:
    Now adding in the gpu makes it look ugly and busy The copper and green pcb really don't match. I called a nickel plating company to get a quote on plating both copper GPU blocks and it was $175 for both! So that's not going to happen. I may switch to the other acetal/copper block and paint the edge of the copper silver. I have another idea for the PCB
    Much better with the gpu off again
  12. #37
    Dec 2008
    Jerusalem, Israel
    looks great! i like this color combo.
    what are you planing to do with the GPU?
    [SIGPIC][/SIGPIC]
    EVGA SR-2 , 2X Intel Xeon 5620, 12X2GB Corsair Domminator 1600 MHZ CL7
    3X GTX580, Corsair AX1200, Lian Li PC-Z70
    3X Dell U2311H, Liliput 7" touchscreen monitor
  13. #38
    Jul 2011
    San Diego
    Quote Originally Posted by arkadur View Post
    I'm part way through coating the board with black liquid electrical tape. That will hide the green, then I'll make a custom back plate and paint to match that will hide any ugliness from the liquid tape
  14. #39
    Jul 2011
    San Diego
    Soo like I mentioned before I really didn't like the green/copper look clashing with the black/red R4E theme:
    So I started to paint the GPU with liquid tape - first coat:
    So here's how it looks now after two coats on both sides:
    You can see some of the texture here, liquid tape is hard to work with - either annoyingly thick, or very thin and see through:
    From this angle the texture isn't as bad:
    However it would look a lot better with a backplate, I'm thinking something like this, smoked acrylic with an etch and a couple of LEDs to light it from the side:
    What do you guys think? Feel free to photoshop up your own suggestions
  15. #40
    Feb 2010
    Wisconsin
    Wow! Never seen that liquid tape idea... that's really slick! (can mask up those gruesome Galaxy cards)
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
  16. #41
    Xtreme Mentor
    Sep 2007
    Dallas
    So are you putting 8800GT's on the RE4 instead of the GTX480's you listed? Why wouldn't you put the best board and GPU's for your gaming? Also, did you just use the black liquid tape to cover the green or are you doing something exotic?
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
  17. #42
    Jul 2011
    San Diego
    Quote Originally Posted by ScottALot View Post
    Yeah some people use it for subzero prep, on those cards it's more for the color.
    Quote Originally Posted by Utnorris View Post
    The 3930K is for my workstation which doesn't game (linux cad box basically) so the 8800gt's are fine for that. 6 cores + max clock is the most beneficial for my work. The workstation gets the good cpus and then they get handed down to the gaming rig. Until I get 2 more U3011's I don't really need more than the 990x/tri gtx480's, possibly some more vram though. Now if I was benching I might swap them over, but for everyday that's how it'll be.
  18. #43
    Xtreme Mentor
    Sep 2007
    Dallas
    Gotcha. By the way, looking good.
    Desk Build
    W/C System
  19. #44
    Jul 2011
    San Diego
    The temporary parts came in to see if I could get some clean routing for the motherboard/ram/gpu loop:
    However it didn't quite work as expected- I couldn't get the 40mm extensions to work with the 5 way rotary snake, however a SLI connector did fit.
    Now I'm not sure whether to:
    - get two more sli connectors (I need this one)
    - use two compression fittings instead
    - get two of the bitspower crystal sli links to match better
    I should probably go with the cheapest as I'm hoping monsoon free's new design will solve the problem for me.
  20. #45
    Mar 2008
    Out of curiosity, did you try to remove the foil found on the Southbridge? I've never encountered something like that and can't seem to find any information on whether you should just clear the thermal paste off it and leave it, or remove it entirely.
    Instructions for the EK waterblock make no mention of it at all, which I find rather odd.
    Bill Cosby: Stewie, what do you think candy is made out of?
    Stewie Griffin: Sunshine and farts! What the hell kind of question is that?!
  21. #46
    Dec 2008
    Jerusalem, Israel
    because of you choose the plexi top - i was connecting the blocks with BP crystal links, straight lines in different high \ levels
    1: RAM block1 > RAM block 2
    2: VRM> chipset
    3: chipset> GPU
    that could be very nice. just think about it.
    i know that hell to disassemble it, but that turn to be very nice setup in the end.
    [SIGPIC][/SIGPIC]
  22. #47
    Jul 2011
    San Diego
    Quote Originally Posted by kgk View Post
    Personally I removed it, I know others have too. I haven't turned on the board yet since though. Still getting the plumbing right.
    2: VRM> chipset
    3: chipset> GPU
    Yes I think the crystal links would look awesome, particularly on show pics with some temporary red dye
    Here's another option but with the cpu loop coming out to the north, it looks busy:
  23. #48
    Mar 2008
    edit: nvm
  24. #49
    Jul 2011
    San Diego
    Got some more parts today:
    3 ssds and a bunch of fittings:
    This meant I could do some leak testing with the gpu/motherboard/ram loop. Still missing the other gpu for now though, but the important thing was to see if the ram block connections were good:
    You can see water on the bottom right of the board. The GPU didnt' have it's spare ports sealed tightened down properly. Didnt' see that leak for a few minutes as it was dripping down the back of the block and was mainly hidden by the card and the block. You can see it coming out and filling up the pci-e socket:
    The bitspower crystal linke sli fittings were part of the order too. The closest one in this photo leaked initially as it had fallen out of the o-ring. They're not that sturdy so it's a bit concerning that they might fall out. We'll have to see how it goes.
    The top view is much nicer now though:
    With red dye the crystal links won't look so out of place.
    That's all for now. Case should be back from powder coating with another 14 gentle typhoons on tuesday, so expect a big update then Until then the board can dry out a bit I need more time for working on the backplates and the reservoirs.
  25. #50
    Jan 2009
    I personally don't care for the LT on the card PCB, but I love everything else
    [3960X 4.8GHz 1.35v] [32GB G.Skill Ripjaws 2133] [EVGA GTX 680 SLI] [ASUS RIVE] [Samsung Spinpoint F1 1TB R0]
    [EK Supreme HF] [EK RIVE Full Board Kit] [Coolgate 120.3 + 120.1] [4 x Scythe GT D1225C12B5AP-15] [BitsPower Compression] [MCP655]
    [3 x Acer S231HL LED 5760 x 1080 2d Surround]
