Results 1 to 3 of 3
Thread: 8120 with 1.3vid ... 1.65v for 5000mhz...i always seem to find the Volt leakers haha
    Jul 2007
    Today i grabbed two 8120's for a friend and I
    ..but both chips are not equal, one ran 4900mhz and the other just as my FX6100 @ 5000mhz with a little more heat .
    Using the 990FXA UD5,,
    The 1.3vid 8120 uses the same Volts for vcore as which my FX6100 does for the same clocks .
    The NB prefers 1.37vid instead of 1.32vid like the FX6100.Probally due to the extra core and heat it creates.
    Whats very interesting is that the other 8120 with 1.285vid did not like going above 4900mhz and 5000mhz stability was horrid .
    Seems to be some truth,, the Higher VID/Vcore chips that use 1.3vid and above stock do like more volts and will most likely be way better clockers for a stable 5000mhz system.
    8120 stock is 1.3vid runs cinebench at 1.648v
    8120 stock 1.285vid @ 5000mhz @1.568v. throwing 1.6v didnt even budge it , giving less was even worse
    Tweaking some more and will try to lower my voltages some on the 1.3vid chip. Like i was saying some of these chips just like volts.
    gOtVolTage!
    "AMD...Like the perfect Storm,...Everything needs to be just right"
    X555x4SuperCore@4450mhz@1.64v..........
    RYZEN 7 1800x/ ASUS ROG STRIX VEGA64/ =EK NICKEL WB, Feser THC 2x360 1x480
    X470 Gigabyte Aorus7, Patriot 3400mhz 16gb dual2x8
    SSD Samsung 970pro,,860EVO
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    my 8120 got 1.381 - 1.387 VID
    need 1.600 - 1.605 @ 5.0GHz for Cinebench 11.5 and other 3DMark
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
    Xtreme 3D Team
    Jan 2009
    Ohio
    If your 8120 has a VID of 1.3v, it is NOT a leaker...
    If your 8120 has a VID of 1.381v, I feel really bad for you...
    I think the ideal VID for 8120 is between 1.25v-1.275v, considering lower clockspeed compared to 8150.
    Smile
