Fix for Zalman CNPS9900Max
Was not impressed with the performance especially after the complicated install. OK the install was not too difficult, just time conuming and makes swapping out a cpu an all day affair if you misplace the ball ended allen wrench that comes with it. Had this Thermalright fan duct going to waste so tried it on for fun and it was almost a perfect fit!
http://www.thermalright.com/new_a_pa..._fan_duct.html
Only works if your cooler flows from front of case to the rear exhaust fan though I suppose it may work with a top 120mm fan if your cooler is oriented to flow upwards. One end of the duct slides right over the rear fins of the 9900max. Sorry. no pics or temp comparison but it was a noticable difference!
Pics from Thermalright - http://www.thermalright.com/new_a_pa...ct_hr01_k8.htm
Note: I am using the orange duct which is shorter than the blue duct.
Reason: add note and link
- You may not post replies
- You may not edit your posts
Forum Rules
