Right I'm a phase cooling noob, I bought a little unit off Ebay for £120 which was apparently tuned and made safe by Gray Mole after the original modder ( Pazza316 )ed it up.
According to weescott ( Owner who had it modded ) Gray tuned it for 220w and for quiet operation using r404.
It has a Chilly 1 Evap, Uprated Condenser and a de-super heater coil with a single 90cfm 120mm fan pulling through the condenser.
These are my temps while Intel Burn Test is running :
During the test my Evap dropped and then held at -20 to -21 degree's C
The CPU temp in AIDA never wen't above 0 degree's C but the core temps did, What temp should I follow?
During idle my Evap is around the -38 degree's C mark
Now as I said I'm a noob so don't really know what my unit should and should not be holding in terms of Evap and CPU load temperatures.
I have thought about running 2x 120mm fans on the condenser for my air flow but I'm unsure if that would help as I've been told that too much air flow can ruin temps as the gas has to be cooled in a set temperature range?
I've also thought about cooling the de-super heater coil also, Would that be a bad idea?
