Results 1 to 14 of 14
Thread: G.SKILL F3-17000CL9Q-16GBZHD testing results
    Champion
    May 2006
    Bangkok, Thailand
    This one kit from G.SKILL is looking interesting for abit cheaper Quad channel kits for SB-E, well let to see what i can do with it
    Setup...
    i7 3960X ES
    ASUS Rampage IV Extreme
    HD6970 CF
    Intel SSD X-25M & Windows 7 64bit
    Antec HCP 1200W
    First try i checking performance of XMP profile is G.SKILL guaranty spec is DDR3-2133MHz CL9-11-9-28-2T compare with
    CR 1T but same clock and timing
    2133C9-11-9-28-2T by XMP boots and tRFC 96
    Then change CR to 1T and i see tRFC is auto change to 120 after boots but other timing still same XMP - 2133C9-11-9-28-1T, tRFC 120
    Sorry For My English
    OverclockZone Team
    THAILAND
    Champion
    May 2006
    Bangkok, Thailand
    Overclocking performance testing
    DDR3-2230MHz CL9-11-10-27-120-1T, 1.66V
    DDR3-2400MHz CL10-12-10-30-120-1T, 1.67V
    Thank you for your time
    OverclockZone Team
    THAILAND
    Apr 2011
    thailand
    llSJ ^^
    May 2008
    Decatur, GA
    My set has CFR instead of BFR like these older kits but they seem to have room to go in terms of raw clock speed. I'm sure they can do 2666+ on Ivy Bridge.
    37x122BCLK RipjawsZ 2133C9 1300MHz 11-13-13-35 2T HyperPi32M.jpg37x122BCLK RipjawsZ 2133C9 1300MHz 11-13-13-35 2T AIDA64.JPG
    i7 4930K
    32GB Corsair Vengeance Pro DDR3-2400C10
    Asus Rampage IV Black Edition
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    May 2008
    Decatur, GA
    Quote Originally Posted by Shiranui Gen-An View Post
    Yes, indeed they can do at least DDR3-2666 on Ivy Bridge
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    Xtreme Mentor
    Dec 2007
    Very nice! I love this kit, hard to beat for the price. Im playing with it now, seeing what it will do on normal voltages.
    Xtreme Mentor
    Dec 2007
    2666c11-13-13-35-1t 2x4gb and 2801c11-14-14-35-2T 4x4gb
    My 2666 TridentX will not pass 32m at 2800mhz with any vdimm
    The 2600 TeamXtreem c10 is quite nice also, but for the money, a good kit of these RipjawsZ is hard to beat IMO.
    Attached Images Attached Images
    Xtreme Mentor
    Dec 2007
    4x4gb RipjawsZ F3-1700c9 @2900c11-14-14-35-2T loose sub-timings 1.85vdimm, w7-64 efficiency is poor but mainly testing the IMC.
    May 2008
    Decatur, GA
    Quote Originally Posted by OC Nub View Post
    Good grief those are some strong sticks. 1.66v for DDR3-2680 C10?!
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    Dec 2007
    Beneath The Remains, Greece
    Is there a reason, other than speed screen shots, to run at these speeds with such high dram, vtt, pll etc voltages when i can run my 2133c9 ripjaws at 2400c11 with much better read/writes/latency scores?
    Sent from my GT-I9000
    Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
    WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
    Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
    May 2008
    Decatur, GA
    It's for the fun of it. Also I found if I run the subtimings on auto, I only need 1.65v set for 2666 C11.
    See? My RipjawsZ mysteriously morphed into TridentX 2666 sticks
    i7 4930K
    2x GeForce GTX 780
    Corsair AX1200
    Cooler Master HAF-X
    Dell U3011
    Nov 2005
    The Netherlands
    Some 1100MHz results (IMC limit) to contribute to the thread:
    better pair:
    worser pair:
    all four together:
