Page 3 of 3 FirstFirst 123
Results 51 to 67 of 67
Thread: ASUS X79 Rampage IV Extreme
  1. #51
    Quote Originally Posted by Eldonko View Post
    Nice you got an excellent chip then
    yes but let's see some retail first , i saw maybe 5 X 3930k in the forums.
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
  2. #52
    Mar 2009
    Poland
    Tell something about this little fan on RIVE chipset ... Is it loud , is it needed ? What about temps, chip runs hot ? Can it be turned off ? There are a lot of concerns...
    Core i7 i920 @4.4Ghz (BCLK209x21) @ 1.39v 24/7 | H2O
    Asus Rampage 2 Extreme X58
    G.Skill Pi Black 3x2GB @1659Mhz 1.65v
    SSD Vertex 120GB & Intel G2 80GB & HDD WD Caviar Black 1TB
    Logitech Illuminated & G500 & Steelseries 5L
    Dell 2209WA
  3. #53
    Moderator
    Jun 2002
    its not noisy, can be disabled in bios. if you disable it, doesnt it become like any other mb without a fan?
  4. #54
    Mar 2009
    Poland
    but well... I guess there were some reasons why they installed that fan.. Does the chip runs so hot and they recommend additional fan ?
    The same situation with other brands, some of them have fan installed like Rampage, Sabertooth others not like P9X79 or GA-X79-UD7 . The question why such diversification...
    Dell 2209WA
  5. #55
    Moderator
    Jun 2002
    originally the chipset has higher wattage with additional uplink and SAS but now no and thus less heat. But the heatpipe from VRM can pass the heat here to aid some dissipation.
  6. #56
    Dec 2007
    @ SwIeR: If that little fan makes any noise at all, its less than my other fans so I cant hear it. If you are doing heavy over clocking on any board you will need to add cooling/fans to keep it cool, and would not be able to hear the board fan even if it did make noise. The memory profiles in the bios actually work well. Support is the best I have seen on a mobo (of any I have owned), and support is from Asus guys posting right here in your forums. Dont think I ever had that type of support with Gigabyte or MSI.
    Unless you are on a budget, or have no need for all the extras, I cant see a reason not to try this board.
  7. #57
    quick wprime test here.
  8. #58
    Xtreme Memory Hoarder
    Mar 2010
    Quote Originally Posted by hiwa View Post
    very nice, ss or ln2?
  9. #59
    Dec 2007
    Great chip! How much vdimm, vccsa did you need to get your memory to pass at that speed with tight timings? Also did you use the Elpida Hyper profile, or Hynix?
  10. #60
    Quote Originally Posted by OC Nub View Post
    some memory test and R4E memory OC giude here
    http://www.xtremesystems.org/forums/...40#post5004440
  11. #61
    Quote Originally Posted by l0ud_sil3nc3 View Post
    very old SS can't even hold single core haha
  12. #62
    Dec 2007
    Thanks, Nice work!!
  13. #63
    Jan 2007
    Can someone qucikly answer this because i'm about to order .... Does this board work with all 1366 CPU blocks? I want to water cool a 3930K but i've read in places that some 2011 boards dont work with 1366 mounting kids. But the Rampage IV comes with some sort of plate adapter so all 1366 blocks/mounting kits should work right??
  14. #64
    Xtremely Addicted
    Dec 2004
    NL
    Yes
  15. #65
    Jan 2008
    Bonnie Scotland / Sunny England
    w00t w00t! I can finally join the club! Picking up my Asus RIVE tonight!!!
    PROJECT :: The Xtreme (WET) Dream!!!
    PERSONAL H2O BESTS :
    E8600 @ 4.8GHz
    E6750 @ 4GHz QX9650 @ 4.6GHz
    i7 920 @ 4.6GHz
    PERSONAL AIR BESTS :
    Sempron140 @ 4Ghz (Stock Cooler)
    i7 3960x @ 5.4ghz (Air Cooler)
    Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
    Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
    Swift_Wraith : "could someone please check bex for a penis?"
  16. #66
    Mar 2010
    still very nice results, I think I am sold on the RIVE, now just to find one in stock somewhere
  17. #67
    Mar 2005
    Finland
    RIVE or RIVF?
    Planning to buy new toys, focus on gaming with SLI or TRI setup with 30" screen but overclocking is almost as high as gaming
    How much there is diff with the sound?
    Asus Rampage IV Formula X79 | EK-MOSFET ASUS RF4 - Acetal Copper
    Core i7-3630K@4.5GHz 1.4V | EK-Supreme HF - Full Copper
    G.Skill 16GB Quad Kit Ripjaws Z (4x4GB), DDR3 1600MHz, CL 9
    EVGA GTX TITAN SC | EK-FC Titan SE Copper - Plexi Full Cover | EK-FC Titan SE Backplate
    Corsair AX1200i
    Samsung 256gb 830
    Intel SSD 160GB X25-M G2
